05-05-2016, 08:35 | #1 (permalink) |
Freak Poster Join Date: May 2015 Location: Chittagong
Member: 2397029 Status: Offline Thanks Meter: 52 | LG D331 firmware needed Read info Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501005137585341420B58FBE6E6C11F Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BASX7 [eMMC] : FLASH_CID : 1501005137585341420B58FBE6E6C11F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 1B1CF4501C8AF79521A5604581E67C6A INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : luv80ss_global_com ProdModel : LG-D331 Device : luv80ss AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : ALPS.W10.24.p0 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1338_MD_WG_TC01_SP_V11_P2_1_w g_n Done! Elapsed: 00:00:07 Reconnect Power/Cable! |
05-05-2016, 09:05 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Can you make "NVRAM read" and upload result log here? It will help me alot. |
05-05-2016, 09:30 | #4 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote: There must be also read sec file. It need for adding that model completely in next CM2MTK updates. | |
