06-29-2017, 07:26 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | LG D370TR Dead boot repair - Unable load infinity firmware. in past I got same working phone and backup. Code: Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Running : MiniOS v1.0 , ver.1.0 , with proto ver.01000001 HWInfo : BaseBand : MSM8610 HWInfo : ChargeLv : 11% HWInfo : MEM_INFO : H4G1d , MEM_LEN : 0x00748000 [eMMC 4 GiB] DevInfo : Model : LG-D370TR , Type : D37010e DevInfo : ANDROID 4.4.2 DevInfo : PSN : BS01S141014002428 , PID : LGD3703a22f1c DevInfo : IMEI : 354111060235089 DevInfo : SecMode : U , Build : U , RCT : 000F4240 SWInfo : SWver : V10e , SW : LGD370TRAT-00-V10d-TUR-XX-APR-22-2016+0 SWInfo : FacSW : LGD370TRAT-00-V10e-OP1-SI-APR-22-2016+0 RegInfo : Region : AME , Provider : GLOBAL Prepare passed, mode 0x00 Boot done! Brand : lge ProdName : w6_global_ame ProdModel : LG-D370 Device : w6 AndroidVer: 4.4.2 SWVersion : LGD370AT-00-V10e-GLOBAL-AME-APR-22-2016+0 Manufact. : LGE LGMxCPU : MSM8610 Done! Elapsed: 00:00:07 Operation : Read Firmware [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD VOLUME UP KEY! 3. Insert USB cable, wait until Download mode screen will appear Wait for phone... Connection opened successfully! Waiting for loader ... Handshake passed! Collect info... Prepare passed, mode 0x00 Boot done! DevInfo : MSM8610__LG-D370TR__D37010e__V10e__AOSv4.4.2__LGD370TRAT-00-V10e-OP1-SI-APR-22-2016+0 Reading Flash Content ... [Read Ok] : gpt_main.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : misc.img [Read Ok] : persist.img [Read Ok] : laf.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : persist_lg.img [Read Ok] : calibration.img [Read Ok] : fact.img [Read Ok] : cust.img [Read Ok] : system.img [Read Ok] : gpt_backup.bin Android Info saved! Read finished! Configuration : MSM8610 / 4.4.2 / V10e Firmware Size : 1645 MiB Done! Elapsed: 00:01:46 I tried same exe and newer but failed. Code: Operation : Identify [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 06985DCA ID_BLOCK_I : 008110E1 ID_BLOCK_L : DF2943BB1A808DB867DC3419E6BD3515 ID_BLOCK_L : 73028C1F10832BB85D98FD2A38F7E1EA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Brand : lge ProdName : w6_global_ame ProdModel : LG-D370 Device : w6 AndroidVer: 4.4.2 SWVersion : LGD370AT-00-V10e-GLOBAL-AME-APR-22-2016+0 Manufact. : LGE SysPatch : KOT49I.A1461330843 QLMxCPU : MSM8610 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Code: Loading firmware ... Firmware load error! Firmware damaged or in unknown format! Send report to support! https://forum.gsmhosting.com/vbb/****************************/?pm9t29c6mhbflb6 |
06-30-2017, 11:57 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. QLM and LGS module firmwares , due different types of vendor-specific data are incompatible, use memory tool, write GPT,DEPLOY,SBL,TZ,EMMC_APPS,RPM,LAF,BOOT and reflash device. |
06-30-2017, 16:12 | #5 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | I put whole tot backup (except system, user data part) in phone but phone still in EDL mode. this backup I took (z3x) from this device 6 month ago when device was working state. Code: Operation : Memory Tool Init [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 06985DCA ID_BLOCK_I : 008110E1 ID_BLOCK_L : DF2943BB1A808DB867DC3419E6BD3515 ID_BLOCK_L : 73028C1F10832BB85D98FD2A38F7E1EA Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000/00000000 Boot Ok! Set default path : C:\InfinityBox\CM2QLM 1.14\phdata\ Ready! Operation : Test Memory [ v1.14 ] Preparing memory test ... Step #1 passed Step #2 passed Memory is Ok! Clean Ok! Operation finished! Operation Write Memory [ v1.14 ] Write selected partitions [32] [0] Write partition : GPT Write from : C:\Users\KHAN\Desktop\SPACE\gpt.bin Write partition Ok! [1] Write partition : MODEM Write from : C:\Users\KHAN\Desktop\SPACE\modem.img Write partition Ok! [2] Write partition : SBL1 Write from : C:\Users\KHAN\Desktop\SPACE\sbl1.img Write partition Ok! [3] Write partition : RPM Write from : C:\Users\KHAN\Desktop\SPACE\rpm.img Write partition Ok! [4] Write partition : TZ Write from : C:\Users\KHAN\Desktop\SPACE\tz.img Write partition Ok! [5] Write partition : SDI Write from : C:\Users\KHAN\Desktop\SPACE\sdi.img Write partition Ok! [6] Write partition : ABOOT Write from : C:\Users\KHAN\Desktop\SPACE\aboot.img Write partition Ok! [7] Write partition : RPMB Write from : C:\Users\KHAN\Desktop\SPACE\rpmb.img Write partition Ok! [8] Write partition : TZB Write from : C:\Users\KHAN\Desktop\SPACE\tzb.img Write partition Ok! [9] Write partition : ABOOTB Write from : C:\Users\KHAN\Desktop\SPACE\abootb.img Write partition Ok! [10] Write partition : PAD Write from : C:\Users\KHAN\Desktop\SPACE\pad.img Write partition Ok! [11] Write partition : MODEMST1 Write from : C:\Users\KHAN\Desktop\SPACE\modemst1.img Write partition Ok! [12] Write partition : MODEMST2 Write from : C:\Users\KHAN\Desktop\SPACE\modemst2.img Write partition Ok! [13] Write partition : MISC Write from : C:\Users\KHAN\Desktop\SPACE\misc.img Write partition Ok! [14] Write partition : PERSIST Write from : C:\Users\KHAN\Desktop\SPACE\persist.img Write partition Ok! [15] Write partition : LAF Write from : C:\Users\KHAN\Desktop\SPACE\laf.img Write partition Ok! [16] Write partition : BOOT Write from : C:\Users\KHAN\Desktop\SPACE\boot.img Write partition Ok! [17] Write partition : RECOVERY Write from : C:\Users\KHAN\Desktop\SPACE\recovery.img Write partition Ok! [18] Write partition : FSG Write from : C:\Users\KHAN\Desktop\SPACE\fsg.img Write partition Ok! [19] Write partition : FSC Write from : C:\Users\KHAN\Desktop\SPACE\fsc.img Write partition Ok! [20] Write partition : SSD Write from : C:\Users\KHAN\Desktop\SPACE\ssd.img Write partition Ok! [21] Write partition : DDR Write from : C:\Users\KHAN\Desktop\SPACE\DDR.img Write partition Ok! [22] Write partition : ENCRYPT Write from : C:\Users\KHAN\Desktop\SPACE\encrypt.img Write partition Ok! [23] Write partition : RCT Write from : C:\Users\KHAN\Desktop\SPACE\rct.img Write partition Ok! [24] Write partition : DRM Write from : C:\Users\KHAN\Desktop\SPACE\drm.img Write partition Ok! [25] Write partition : SNS Write from : C:\Users\KHAN\Desktop\SPACE\sns.img Write partition Ok! [26] Write partition : FACTORY Write from : C:\Users\KHAN\Desktop\SPACE\factory.img Write partition Ok! [27] Write partition : FOTA Write from : C:\Users\KHAN\Desktop\SPACE\fota.img Write partition Ok! [28] Write partition : SBL1B Write from : C:\Users\KHAN\Desktop\SPACE\sbl1b.img Write partition Ok! [29] Write partition : MPT Write from : C:\Users\KHAN\Desktop\SPACE\mpt.img Write partition Ok! [30] Write partition : CUST Write from : C:\Users\KHAN\Desktop\SPACE\cust.img Write partition Ok! [31] Write partition : EKSST Write from : C:\Users\KHAN\Desktop\SPACE\eksst.img Write partition Ok! Operation finished! Close MemoryTool session Done! Elapsed: 00:34:51 |
06-30-2017, 16:25 | #6 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Quote:
use last version of lg mobile flash the last version of firmware to the working device and after read this firmware whith qlm module or lgs module and write it to the dead mobile | |
07-01-2017, 07:52 | #9 (permalink) | ||
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
I tried too many ways and combinations but phone still stick with EDL. | ||
07-01-2017, 10:01 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Reflash CM2 files , if device will be in EDL mode still - then, mostly, that mean some HW or other problem. That device uses plain security, what mean it not reflected by downgrade. Also, first, make whole low erase - select all parts and do wipe. |
07-01-2017, 16:29 | #11 (permalink) | |
Member: 355782 Status: Offline Thanks Meter: 1,265 | No DEPLOY, EMMC_APPS, partitions not shown, I try write gpt , init gpt. gpt from kdz size 512kb cant write due to size, can init part but still those parts missing. Quote:
I got D325 factory xml files which are same D370TR I replace data parts but cm2 give error while loading them. (qfil drop while booting with loader err) I open phone and clean, PCB looking fresh and hardware looks fine, but I know this thing not decrease chances of hardware, customer say phone dead after continuous battery warning. | |
12-17-2017, 12:14 | #12 (permalink) | |
Freak Poster Join Date: Apr 2015 Location: Jhang,Pakistan
Member: 2385950 Status: Offline Sonork: 100.1678371 Thanks Meter: 8 | Quote:
I Think Its Battery Problem What You Say? | |
