05-20-2016, 12:41 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | LG D686 and D682TR Stuck at Recovery Mode.. u have any idea or solution for these devices.. after succefully flashing devices stuck at recovery mode.. |
05-21-2016, 08:18 | #3 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
Code: Card found : S/N : 3EB438F8 , v0130 Chinese Miracle II [MTK module] v 1.46 Operation : Check / Read Info [ v1.46 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 44 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040502A169BE4199 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 055DB331B6FFD0786CDDF7FE0F0765FD INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : luv90ss_open_tr ProdModel : LG-D682TR Device : luv90ss AndroidVer: 4.4.2 MTKxCPU : MT6577 MTKxPRJ : ALPS.W10.24.p0 SECURITY : BTMAC Addr : 22221A1A1A1A WiFi MAC : 000000000000 MODEM : BaseBand : MT6577_S00_MAUI_11AMD_TC1_SP2_V34_P2_1_3g_n Done! Elapsed: 00:00:13 Reconnect Power/Cable! | |
11-28-2016, 10:02 | #8 (permalink) | |
HW check.. Code: Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 61 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040502A11153413B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x46E20CEAEDE5BC8026552061643E7CC6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery ) [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d2G8 , 0x1D2000000 , 7456 MiB [eMMC] : CID : 90014A4838473264040502A11153413B [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x40000000 , 1024 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1D [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:02:55 Reconnect Power/Cable! | |
11-28-2016, 10:39 | #9 (permalink) | |
after succesfully flashing stucks at LG logo at this time.. after ALL formatting again stucks at recovery logo.. Code: ======= Flash Files set for flashing : [ MCU ] : MT6577__LGE__LG-D682TR__luv90ss_open_tr__luv90ss__ALPS.W10.24.p0__Android_4.4.2.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 61 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040502A11153413B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x46E20CEAEDE5BC8026552061643E7CC6 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : lge ProdName : luv90ss_open_tr ProdModel : LG-D682TR Device : luv90ss AndroidVer: 4.4.2 MTKxCPU : MT6577 MTKxPRJ : ALPS.W10.24.p0 ISPFF ID : 6577 , TARGET ID : 6575 Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6577__LGE__LG-D682TR__luv90ss_open_tr__luv90ss__ALPS.W10.24.p0__Android_4.4.2.ispff Init Ok , Sending blocks ... Write done , 7456 blocks sent Done! Elapsed: 00:27:31 Reconnect Power/Cable! | |
08-18-2017, 09:32 | #13 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2702310 Status: Offline Thanks Meter: 1 | my device lg d686 problms auto recovery mode Hi frd Lg D686 full flashing Done but problms not sucss Checking data...OK Platform: LG MTK Selected port: COM15 Selected baudrate: 921600 Selected model: D686 Selected USB connection type Please, reconnect battery and connect cable...OK Phone found at port COM27 Phone found. CPU name: MT6575 CPU revision: 8B00.CB00.E201.0000 Setting power state...OK Prepairing loader...OK Sending loader...OK Synchronizing with loader... Loader version: 3.2.132 Detecting flash chip...OK Detecting EMMC flash chip...OK Reading info...OK Opening "LGD686AT-00-V20b-AME-XX-SEP-24-2014+0.oct"... Writing Firmware... Checking partition... Formating filesystem...OK Unlocking Bootloader...OK Writing FILE_INFO...OK Writing MBR...OK Checking partition...OK Writing EBR1...OK Writing EBR2...OK Writing EBR3...OK Writing UBOOT...OK Writing BOOTIMG...OK Writing RECOVERY...OK Writing SEC_RO...OK Writing LOGO...OK Writing PERSIST...OK Writing CUST...OK Writing ANDROID...OK Writing CACHE...OK Writing USRDATA...OK Checking partition...OKOK Writing firmware done! Performed by 2.7.3 Software version. SOLUTION PLZ |
The Following User Says Thank You to mahendar singh For This Useful Post: |
