07-08-2016, 07:58 | #1 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | how to flash qmobile i7i ? 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 78 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac |
07-08-2016, 08:48 | #3 (permalink) |
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | Operation : Check/Read Info [ v1.19 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 78 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! Unknown structure detected! Check correct model selection! Elapsed: 00:00:26 Reconnect Power/Cable! |
07-08-2016, 10:58 | #4 (permalink) |
No Life Poster Join Date: Jun 2014 Location: Infinity Box Team
Member: 2197212 Status: Offline Sonork: N/A Thanks Meter: 680 | Unknown structure detected! Check correct model selection! As i Know if you Have Infinity Box Read File Then You can Flash . but with above error you can't read write . |
07-08-2016, 12:41 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, What is phone condition? .pac file selected is for same model or other? Try with Both Generic and A5 cpu selection, also try with sldr files manually. Br. Infinity Box Support Team. |
11-11-2016, 07:03 | #9 (permalink) |
No Life Poster Join Date: May 2016 Location: ...:::cAtCh mE iF U cAn:::...
Member: 2570477 Status: Offline Thanks Meter: 427 | Also Face this error Phone found! [ 5 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! |
01-07-2017, 14:31 | #10 (permalink) |
Insane Poster Join Date: Aug 2016 Location: pakistan Age: 31
Member: 2607208 Status: Offline Sonork: 100.1674686 Thanks Meter: 26 | i7i boot key with miracle boot jig Chinese Miracle II [SPD module] v 1.24 Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD 773x eMMC loader v3 Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : QMobile_i7i Model Brand : Qmobile Model Device: QMobile_i7i AndrVersion : 5.1 BaseBand CPU: QMOBILE_I7I CompileDate : 4/6/2016 9:24:37 AM Project Ver : QMobile_i7i_MP_06_04 Model Ext : QMobile i7i ExtraInfo : HWInfo not exists, normal phone Elapsed: 00:00:29 Reconnect Power/Cable! |
01-07-2017, 14:35 | #11 (permalink) |
Member: 2607208 Status: Offline Sonork: 100.1674686 Thanks Meter: 26 | i select .pac file when i flash this error help me infinity-box team 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 7 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! |
01-07-2017, 23:16 | #13 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | It must be your driver issue.. uninstall old drivers.install drivers from support.. and use volume up and down as boot key.. Dont forget to use proper cpu selection from list |
01-08-2017, 13:20 | #14 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | Fully Supported Here you Go http://forum.gsmhosting.com/vbb/f296...ision-2135902/ |
08-22-2017, 09:07 | #15 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2476003 Status: Offline Sonork: 100.1664157 Thanks Meter: 11 | hi brothers can any one help me i want to flash Q i7i i can not flash it due to this error hone found! [ 78 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SC773x eMMC v2.0 Loader Infinity Sending FLASH FDL FLASH FDL Ready! Boot Ok! |
