lg e 445 after flash network service disabled the phone was just with viruses i flash it using cm2 firmware readed by a member after flash phone is working properly but network service is disabled (no network ) |
fixed ..............................thank you |
how do you fix this phone i have too set e445 i flashed with full dump with cm2 i repair imei by z3x but the phone stil services desactive emergency yours |
lg e 445 after flash network service disabled just "fix unknown baseband" |
can you give me the steps plaese this my log Card found : S/N : 4BA15735 , v0134 Chinese Miracle II [MTK module] v 1.56 Operation : Check / Read Info [ v1.56 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! SECURE BOOT Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! i try both with auto and only sp:auto and sp:selec model |
bibi019 SP Select Model (6571-6797) -> LG E44x\E45x\E46x -> Extra Tab -> "Fix Unknown Baseband" |
thanq soooooooooooooooooooooomuch done |
