Old 06-25-2016, 20:24   #1 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 212
lg e 445 after flash network service disabled
the phone was just with viruses i flash it using cm2 firmware readed by a member after flash phone is working properly but network service is disabled
(no network )
Old 06-26-2016, 00:37   #2 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 212
fixed ..............................thank you
Old 01-11-2017, 17:00   #3 (permalink)
Member: 69250
Thanks Meter: 27
how do you fix this phone
i have too set e445 i flashed with full dump with cm2 i repair imei by z3x
but the phone stil services desactive
emergency
yours
Old 01-11-2017, 23:02   #4 (permalink)
Member: 874289
Thanks Meter: 10
just "fix unknown baseband"
The Following User Says Thank You to _hydra_ For This Useful Post:
Old 01-12-2017, 09:46   #5 (permalink)
Member: 69250
Thanks Meter: 27
can you give me the steps plaese
this my log
Card found : S/N : 4BA15735 , v0134
Chinese Miracle II [MTK module] v 1.56
Operation : Check / Read Info [ v1.56 ]
Wait for phone...
Phone found! [ 43 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[DA_ERROR] : Correct BOOT CONFIGURATION not found for target!
SECURE BOOT Mode Enabled! Try select NORMAL SP Mode!
Boot Error!
Operation Failed
Elapsed: 00:00:14
Reconnect Power/Cable!
i try both with auto and only sp:auto and sp:selec model
Old 01-12-2017, 10:24   #6 (permalink)
Member: 874289
Thanks Meter: 10
bibi019
SP Select Model (6571-6797) -> LG E44x\E45x\E46x -> Extra Tab -> "Fix Unknown Baseband"
The Following 2 Users Say Thank You to _hydra_ For This Useful Post:
Old 05-19-2018, 12:42   #7 (permalink)
Crazy Poster
Member: 764794
Thanks Meter: 8
thanq soooooooooooooooooooooomuch done
Page generated in 0.24297 seconds with 7 queries
