04-24-2016, 17:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Al-Ahsa Saudi Arabia Age: 35
Member: 253510 Status: Offline Sonork: 100.1672352 Thanks Meter: 3,534 | LG E445 Firmware for CM2 Users Check Inside!! Read Info!! Code: Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3B168512B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : FD88F3FE69557A0025E6C130F657D976 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : lge ProdName : vee4ds_open_esa ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 Done! Elapsed: 00:00:09 Reconnect Power/Cable! Read Flash!!! Code: Wait for phone... Phone found! [ 10 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3B168512B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : FD88F3FE69557A0025E6C130F657D976 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Read Ok , collect info Brand : lge ProdName : vee4ds_open_esa ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 Saved to : C:\Users\Muhammad Irfan\Desktop\LG E445 MTK6575\MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13__Android_4.1.2.ispff Done! Elapsed: 00:20:42 Reconnect Power/Cable! Finish at : [4/24/2016 / 6:01:13 PM] Dont Forget Press Thanks Button Regards .::M Irfan::. |
The Following 46 Users Say Thank You to .::M Irfan::. For This Useful Post: |
04-25-2016, 06:41 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | you need full dump will be good if you mark to factory firmware option from read flash tab and read factory firmware again |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
04-25-2016, 12:32 | #5 (permalink) | ||
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Quote:
The Following 3 Users Say Thank You to 4G Telecom For This Useful Post: |
04-25-2016, 15:11 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Because in update logs mentioned only Dump read/write. Not FW. FW support will follow for E series. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
08-29-2016, 12:11 | #10 (permalink) |
Freak Poster Join Date: Sep 2007 Location: BISMI TRONICS
Member: 598334 Status: Offline Thanks Meter: 111 | after writing this frimware, phone is disable, no network repaired imei, tried unlock , but still phone in disable mode |
The Following 2 Users Say Thank You to coolshahul For This Useful Post: |
09-12-2016, 03:11 | #11 (permalink) |
Freak Poster Join Date: Aug 2014 Location: Enugu
Member: 2241097 Status: Offline Thanks Meter: 17 | Error while trying to write the firmware.... Operation : Flash [ v1.54 ] ======= Flash Files set for flashing : [ MCU ] : MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13_ _Android_4.1.2.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 582 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A3B1D03107 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xB3F213D0024844834EE9CAFDAC777FDA INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Brand : lge ProdName : vee4ds_open_esa ProdModel : LG-E445 Device : vee4ds AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V13 ISPFF ID : 6575 , TARGET ID : 6575 Flash pre-erase disabled Write Flash now ... [ MCU ] : MT6575__LGE__LG-E445__vee4ds_open_esa__vee4ds__ALPS.JB.TC1.SP.V13_ _Android_4.1.2.ispff Init Ok , Sending blocks ... Write failed Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:01:31 Reconnect Power/Cable! |
The Following User Says Thank You to SAGACITY For This Useful Post: |
11-12-2016, 01:14 | #12 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
Yes, I Also Facing Same Problem, IMEI, Baseband, Okay, Even Tried With Repair IMEI As IMEI Sticker (35XX & 911X Both). Even I Have Another Dump Which Was Read By Myself But That's Also Not Work. With SIM Show "Service Disabled" & Without SIM Show "No SIM Card". I Have Two Cellphones & Two Dump But Same Problem. | |
The Following User Says Thank You to MyGSM World For This Useful Post: |
11-12-2016, 03:45 | #13 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
What if write scatter file?? | |
The Following User Says Thank You to chandanps18 For This Useful Post: |
11-30-2016, 19:35 | #14 (permalink) |
No Life Poster Join Date: Jun 2004 Age: 51
Member: 69514 Status: Offline Thanks Meter: 66 | I too have same problem. service disabled with sim.After writing this file. How to solve it please help infinity team. |
The Following User Says Thank You to jatjag For This Useful Post: |
