10-03-2016, 13:23 | #1 (permalink) | |||
No Life Poster Join Date: Dec 2015 Location: hossting
Member: 2501288 Status: Offline Thanks Meter: 328 | LG E460 stuck at logo. [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! 1: setting sp lg E46x Quote:
10-03-2016, 16:31 | #4 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 134586 Status: Offline Thanks Meter: 22 | same problem with e445 Operation : Check / Read Info [ v1.57 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! SECURE BOOT Mode Enabled! Try select NORMAL SP Mode! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
10-06-2016, 18:02 | #5 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | lg e455 Operation : Flash [ v1.57 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 105 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! |
10-06-2016, 19:06 | #7 (permalink) |
Member: 2501288 Status: Offline Thanks Meter: 328 | all work fine now Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600FF681950A3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0x595FB49A39FE6561F5D1BB1EEF4FE78B INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : lge ProdName : vee5nfc_open_eu ProdModel : LG-E460 Device : vee5nfc AndroidVer: 4.1.2 SWVersion : LGE460AT-00-V10p-EUR-XX-JAN-07-2014+0 CU_SWVer : E46010p-EUR-XX MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.TC1.SP.V6 [Read Ok] : preloader_vee5nfc_open_eu.bin [Read Ok] : DSP_BL [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : EBR2 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : persist.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6575 / V1.0.0 / vee5nfc_open_eu / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1091 MiB Scatter saved to : xxxxxxxxxxxxxxxxxxxxxxx MT6575__lge__LG-E460__vee5nfc__4.1.2__LGE460AT-00-V10p-EUR-XX-JAN-07-2014+0\ All done! Done! Elapsed: 00:07:06 Reconnect Power/Cable! |
The Following User Says Thank You to Steve-1 For This Useful Post: |
11-26-2016, 12:21 | #8 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
as i see this firmware has not scatter file..? and can u pls upload the file..? | |
11-13-2017, 12:47 | #9 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Jamalpur Dhaka Bangladesh
Member: 2624892 Status: Offline Thanks Meter: 88 | Operation : Check / Read Info [ v1.58 ] Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! plz help me |
11-13-2017, 14:46 | #10 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Code: [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! this means not supported by cm2 |
11-26-2017, 07:42 | #11 (permalink) |
Junior Member Join Date: Jul 2017 Location: Oman Age: 26
Member: 2735802 Status: Offline Thanks Meter: 1 | Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 0633 BB_CPU_NME : [MediaTek] MTxxx BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage [DA_ERROR] : Correct BOOT CONFIGURATION not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! plese help me |
11-26-2017, 15:06 | #12 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Post details about phone model etc. Br. Infinity Box Team. | |
01-18-2018, 10:49 | #14 (permalink) |
Freak Poster Join Date: Jul 2014 Location: pakistan Age: 35
Member: 2215285 Status: Offline Sonork: [email protected] Thanks Meter: 22 | any solution for mobicell rebel....privacy lock..... cm2 error...............correct boot configuration not found for target |
