03-16-2009, 16:53 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | LG F2250 after unlock no network COM4 [VCP0] selected module v1.37 Device: LG-F2400 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 356560000102429 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000102429_LG-F2400_20090316-131225.B1E.bin ........................ Check flash Done Check space ... current eeprom imei: 356560000102429 ........................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 43 sec Remove/Install battery now ! Guljee |
11-16-2009, 11:46 | #4 (permalink) |
Junior Member Join Date: Dec 2008
Member: 922107 Status: Offline Thanks Meter: 0 | LG F2400, after unlock no network hello same problem. after unlocking lg f2400, no network i have reset the phone, 2945#*#, the same i have write the files that infinity saves, the same help me pls! |
12-29-2010, 08:40 | #5 (permalink) |
Freak Poster Join Date: Jan 2009 Location: RAWALPINDI Age: 40
Member: 951666 Status: Offline Thanks Meter: 64 | bro u have to select local network for signals. Go to settings>>then on network settings >> then go to preferred button on 3rd option. there will be a huge lists of 555 networks. select ur expected network. if u are in pakistan ur desired networks will be listed on 325 to 329. BR |
12-29-2010, 09:11 | #6 (permalink) |
No Life Poster Join Date: Nov 2008 Location: pakistan
Member: 898041 Status: Offline Sonork: 100.1593459 Thanks Meter: 549 | brother u select wrong model in the list, you select model f2400 and your model in hand is f2250. Now download flash files of correct model and full flash your phone, your problem will b solve. bro |
lg me770 after unlock no network | kamraankisskiss | Infinity-Box | 2 | 03-28-2010 17:38 |
lg kp 202 after unlock no network plz help | unlock_solution | FuriousGold | 2 | 11-24-2009 14:31 |
lg l342i after unlock no network | bhoybits99 | Infinity-Box | 2 | 05-19-2009 08:19 |
Ust pro 2, E250 after unlock No network & after eeprom No Speaker! | Wais777 | UST Pro II | 7 | 04-09-2008 23:55 |
lg 8120 after unlock no network . . | harish35200 | LG | 7 | 02-10-2007 05:54 |
