12-18-2008, 15:35 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | LG F2250 Unlock Done. Cable : 7050 COM4 [VCP0] selected Device: LG-F2400 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 356560000107121 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000107121_LG-F2400_20081218-192347.B1E.bin ........................ Check flash Done Check space... current eeprom imei: 356560000107121 ........................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 48 sec Remove/Install battery now ! |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
12-18-2008, 19:07 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. Please, read flash from this phone and send full flash backup files to [email protected] | |
12-30-2008, 16:44 | #3 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Aunlock Age: 43
Member: 80354 Status: Offline Sonork: 100.1577575 Thanks Meter: 21,659 | LG F2250 unlocked with infinity select f2400 ;-) cable 7050 COM3 [VCP3] selected module v1.36 Device: LG-F2400 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud ... 460800 Set baud Done Check flash ... current eeprom imei: 356560000186562 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000186562_LG-F2400_20081230-204238.B1E.bin ........................ Check flash Done Check space ... current eeprom imei: 356560000186562 ........................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 51 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to Ja\/\/aD For This Useful Post: |
02-14-2009, 17:40 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | COM3 selected Device: LG-F2400 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 356560000084221 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000084221_LG-F2400_20090214-163858.B1E.bin ........................ Check flash Done Check space... current eeprom imei: 356560000084221 ........................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 52 sec Remove/Install battery now ! |
The Following User Says Thank You to amanvir For This Useful Post: |
03-16-2009, 09:16 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | LG F2250 after unlock no network this is log ==== log: [3/16/2009 1:11:59 PM] ==== COM4 [VCP0] selected module v1.37 Device: LG-F2400 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 356560000102429 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000102429_LG-F2400_20090316-131225.B1E.bin ........................ Check flash Done Check space ... current eeprom imei: 356560000102429 ........................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 43 sec Remove/Install battery now ! Guljee |
03-18-2009, 18:54 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I don't think that problem with network may be a result of unlock procedure. You can restore original eeprom backup (it was created automatically during unlock) and you can check phone in it's original state. |
04-11-2009, 14:09 | #9 (permalink) |
Freak Poster Join Date: Dec 2008 Location: smart- key
Member: 917810 Status: Offline Thanks Meter: 45 | COM6 [VCP0] selected module v1.36 Device: LG-F2400 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881500010001:89881500000000 flash: 89881500010001:89881500000000 flash: Intel 128MBit-B Strata B 16Mb id: 00005272 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 356560000192214 file saved: C:\Program Files\InfinityBox\LGA\eeprom_356560000192214_LG-F2400_20090411-180742.B1E.bin ........................ Check flash Done Check space ... current eeprom imei: 356560000192214 ........................ finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 48 sec Remove/Install battery now ! |
The Following User Says Thank You to kashif_faiz For This Useful Post: |
LG KP170 UnloCkeD dOne by Rocker LG | jakoy | Rocker Dongle (By Legija) | 1 | 05-25-2009 07:04 |
LG U990 unlocked! done by Easy-Unlocker | vinay_sharma | Easy-Unlocker | 1 | 04-14-2009 10:32 |
LG-KP200 unlock done | yhob | Infinity-Box | 1 | 08-14-2008 16:57 |
LG-KG245 unlock done | yhob | Infinity-Box | 2 | 07-18-2008 11:34 |
Lg U8290 Unlock Done But | ch_rathore | Redbox | 23 | 08-08-2006 19:12 |
