02-12-2017, 21:02 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Algeria
Member: 2105719 Status: Offline Thanks Meter: 20 | LG G Flex LS996, Add support! Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.10 Operation : Memory Tool Init [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 810 [MSM8994] ID_BLOCK_S : 004B7B06 ID_BLOCK_I : 009400E1 ID_BLOCK_E : 004B7B06 ID_BLOCK_L : FAEE86D60EA35B728066ECBAC6E807A4 ID_BLOCK_L : 405BF0C7333293FEFA2DA53A3056147B Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 810 [MSM8994] ID_BLOCK_S : 004B7B06 ID_BLOCK_I : 009400E1 ID_BLOCK_E : 004B7B06 ID_BLOCK_L : FAEE86D60EA35B728066ECBAC6E807A4 ID_BLOCK_L : 405BF0C7333293FEFA2DA53A3056147B Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Report Post |
02-13-2017, 02:57 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Hello, Code: Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! |
The Following User Says Thank You to chandanps18 For This Useful Post: |
02-15-2017, 23:51 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Unfortunately such device will not be supported in near time under QLM module ( ETA is completely unknown ) Will try order similar device and check it. There is exists atleast one alternate way. |
02-16-2017, 00:37 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I will add few LG on MSM8992 and few on MSM8994. But have no idea which models they are. 1.11 follow on end of this week. |
06-05-2017, 11:07 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
LS996 (msm8994) is not of them.. Code: Operation : Identify [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 810 [MSM8994] ID_BLOCK_S : 005C2820 ID_BLOCK_I : 009400E1 ID_BLOCK_E : 00310000 ID_BLOCK_L : DCD4ACF034857554FE4CD69CE8C6219A ID_BLOCK_L : 7168C3F60003BCEF0B3E942D1F67054A Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! | |
