03-05-2017, 14:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | MT6580_SAMSUNG_SM-G9350_hero2qltechn_6.0.1_ALPS.L1.MP6.V2.19_HCT6580 .WEG.A.L_P55 Please I have dead Galaxy S7 edge one and need good firmware to revive it Phanks in advance |
03-05-2017, 16:29 | #3 (permalink) | |
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | Quote: I have flashed with this firmware and phone dead I flashed back the buckp still dead Batt full charget Code: Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 63 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505070006DFCBB2A9 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505070006DFCBB2A9 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x4B1992B10791619677C2EA6ABFC310B2 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6580 , Project : hct6580_weg_a_l , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 4318 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001C80000-0x0000000003320000 Erase : 0x00000000050A0000-0x00000001CBEE0000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_hct6580_weg_a_l.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:03:07 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:18 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:50 Reconnect Power/Cable! | |
03-26-2017, 16:33 | #5 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2699253 Status: Offline Thanks Meter: 0 | MT650 SM-G9350 Firmware I may have the same model that you have: From the back of my phone: Made In Vietnam Samsung SM-G9350. I tried the above firmware you mentioned, my phone was dead. Then I tried this link: It worked but my phone lost all the info like AP, CP, and CSC. The best one from this link was the number 1 or number 3 (not the upgrade). Using the SP Flash version 1.63 to flash. Now I look for someone could help me to put all info back to my phone like the CSC, the AP and so on. I would like to learn how to do it step by step. I just posted some info about my phone and hope someone could help me how to fix it. Springxuan Too bad. I could not help you with the link because the forum rule that I must have 10 posts to the forum before I can post a link! Sorry...... |
