10-25-2009, 14:37 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | LG GB102 Unlock failed COM9 [VCP0] selected module v1.70 Device: LG-GB102 Checking data, wait... Action: unlock direct unlock method #1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .01 ULC2GL O2 GB102GO 04 FL 49 V10b 262-07 MAR-25-2009 +0 j Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091025-193156.B1E.bin loading data... data loaded imei: 353999XXXXXXXX reading eeprom-security_3539990XXXXXXXX... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903317138600_20091025-193157.B1E.bin reading eeprom-complete_353999XXXXXXXX... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_3539990XXXXXXXX_20091025-193203.B1E.bin backup critical area Done Check memory ... loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... data loaded code: 66012856 error: not locked or unknown eeprom Check memory Failed Finished, time used: 26 sec Remove/Install battery now ! I also try with different baud rate but still same please post solution as soon as possible. Waiting for your kind response. Kind regards, Vicky |
10-27-2009, 08:56 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Select Read Unlock Code And Press SP-UNLOCK Its Workng COM4 [VCP2] selected module v1.70 Device: LG-GB102 Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-17 1.0 TMO_UK GB102 01 FL 44 V10a 234-30 M Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-static_20091025-155032.B1E.bin loading data... data loaded imei: 35399903240524900 reading eeprom-security_35399903240524900... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-security_35399903240524900_20091025-155032.B1E.bin reading eeprom-complete_35399903240524900... file saved: C:\Program Files\InfinityBox\Pana01\LG-GB102_eeprom-complete_35399903240524900_20091025-155034.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 76059459 Finished, time used: 14 sec Remove/Install battery now ! Br UMER |
The Following User Says Thank You to maplegsm For This Useful Post: |
10-27-2009, 15:04 | #4 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Here Is Ur Code: 66012856 Just Put No Accepted Sim Card Enter Code And Press OK!! Br UMER |
10-27-2009, 19:20 | #5 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | Thanks all for reply but phone is not accepting code I try 2945#20001# but nothing happen I try keep flashing firmware/eeprom and unlock code has change, I also try test sim but still same error. I think it need special flash file like KP600 found in this forum by infinitysupport. Please give solution like KP600. Thanks in advance. Waiting for your kind response. Kind regards, Vicky |
10-27-2009, 19:29 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | Quote:
Just select LG KP100 as phone model with KE500 cable and press unlock. | |
10-27-2009, 20:02 | #7 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | @di@bila I have do it already also have flash with KP100 firmware/eeprom but still not success. Thanks for reply. Kind regards, Vicky |
LG GB102 Unlocking | oneeba | HWK | 18 | 09-12-2011 11:57 |
help lg gb102 unlock[ANSWERED] | ahmedao1 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 7 | 10-19-2010 12:22 |
lg gb102 unlock done | m_choko | Multi-Box | 0 | 01-04-2010 16:20 |
Lg KP130 unlock failed | lobalt | PolarBox 3 | 3 | 05-18-2008 14:23 |
LG 8120 Unlock Failed!!!! Help | tittu | LG 3G (USB-Smart) | 10 | 02-19-2006 14:38 |
