LG H324T can identify Dear Bro Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : 00B000B000B000B000B0000000000000 eMMC Flash : NOT INSTALLED Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! Also I want to flash the set....but I don't have the file. anyway to revive the set? Tx |
current condition no download mode no recovery Only "Media Tak usb port" ---under Ports (com&lpt) Tx |
It have emmc inside. Quote:
LG H324T As per the update from here http://forum.gsmhosting.com/vbb/f475...-more-2067136/ it is fully supported. Could you pls advice me more bro Tx |
Is it possible to flash the set through cm2 bro via kdz file bro? or is there any way to recover this set Thanks |
