Old 12-02-2017, 13:00   #1 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 127
LG H324T can identify
Dear Bro
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : 00B000B000B000B000B0000000000000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:26
Reconnect Power/Cable!
Also I want to flash the set....but I don't have the file.
anyway to revive the set?
Tx
Old 12-02-2017, 13:04   #2 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 127
current condition
no download mode
no recovery
Only "Media Tak usb port" ---under Ports (com&lpt)
Tx
Old 12-02-2017, 13:33   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,596
It have emmc inside.
Hw.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-03-2017, 06:38   #4 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 127
Hw.
This model number
LG H324T
As per the update from here
Infinity Chinese Miracle-2 Mediatek v1.44 - LG Leon/Spirit series support and more
it is fully supported.
Could you pls advice me more bro
Tx
Old 12-03-2017, 07:23   #5 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 127
Is it possible to flash the set through cm2 bro via kdz file bro?
or is there any way to recover this set
Thanks
Page generated in 0.23612 seconds with 7 queries
