03-19-2016, 14:03 | #1 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Lg H540 Repair..? any chance to repair boot H540..? Read Info; Code: Operation : Check / Read Info [ v1.44 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420022B3543F823F Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420022B3543F823F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 7C9D801F9FEFA63AEFABB85D2134A584 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! SECURITY : BTMAC Addr : 365B83DE920B WiFi MAC : 000000000000 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Code: User selected DumpFile , extracted : preloader_muse6592m_p1s3g_l.bin Operation : Init Preloader [ v1.44 ] Supported HW by Preloader : FlashID [0] CID : 150100513758534142 , Name : Q7XSAB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513732534D42 , Name : Q72SMB , Vendor : 15 , [SAMSUNG] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6592 BB_CPU_NME : [MediaTek] MT6592_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8A NAND Flash : NOT INSTALLED eMMC Flash : 150100513732534D420022B3543F823F Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D420022B3543F823F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 7C9D801F9FEFA63AEFABB85D2134A584 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 150100513758534142 , Name : Q7XSAB , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513732534D42 , Name : Q72SMB , Vendor : 15 , [SAMSUNG] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 1799 PartTable Init Ok , Count : 24 All Done Done! Elapsed: 00:00:09 Reconnect Power/Cable! |
03-19-2016, 15:26 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Can't say anything yet, because not have such phone. During next week will try get few MT6592 LG samples and make support for them. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
03-19-2016, 15:28 | #3 (permalink) | |
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
btw i will wait for ur good news.. | |
03-19-2016, 15:31 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | LG little bit differs from standard MTK flow, so, better check all things before, make all test then make update with support for rest samples. |
05-01-2017, 16:24 | #6 (permalink) |
Junior Member Join Date: May 2017
Member: 2712623 Status: Offline Thanks Meter: 1 | i have lg h540, its working. i cant root it because its marshmallow. and i didnt fine yet root method for version 6.0. i tried the older procedure ( lollipop) but it cant work anymore for marshmallow. I hope somebody will share their idea for rooting marshmallow for h540. thanks |
The Following User Says Thank You to yannca For This Useful Post: |
