lg k200 format with help of pinfinder logs of pinfinder software version: 1.17 cable type: HF 4 pin (L4A) platform: MT: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 4, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6219 result: Rx:3 Tx:2 time required: 4 sec Power On ! format logs of lf kg200 detected CPU: MT6226MA Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6219B,E02 Date: 2005.04.12 Version: 1.0 Version: 7S7331IN00-001-R1C Version: EP1 60 byte(s) read imei: 35282701257698 connection Ok building list... done items to clear: 218 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 218 of 218 building list... done items remains: 0 Finished, time used: 42 sec Remove/Install battery now ! here is imei rebuild logs Action: imei Model: LG-KG200 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 57600 error: connection failed ! operation failed ! Finished, time used: 5 sec Power off phone now ! Imei 35282701257698 already was repaired: 12/31/2008-6:46:21 PM Continue with this imei ? Action: imei Model: LG-KG200 Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 230400 error: connection failed ! operation failed ! Finished, time used: 49 sec Power off phone now ! Imei 35282701257698 already was repaired: 12/31/2008-6:47:13 PM Continue with this imei ? Action: imei Model: LG-KG200 Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6219B, E0 Hardware version: EP1 Software version: 7S7331IN00-001-R1C" Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 135790246811220 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei: 352827012576989 verification Ok Finished, time used: 5 sec Power off phone now ! :):):):):) |
thnx bro u r doing very well with infinity keep it up nd post ur every log here: regards Kmax |
hello! thank you for sharing your experience!! |
