Old 12-31-2008, 14:32   #1 (permalink)
joni_rajpura's Avatar
Member: 508072
Thanks Meter: 1,621
Wink lg k200 format with help of pinfinder
logs of pinfinder
software version: 1.17
cable type: HF 4 pin (L4A)
platform: MT: MT62xx (autodetect)
searching adapter at COM5...
adapter found, version: 2000
pins: 4, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
CPU: MT6219
result: Rx:3 Tx:2
time required: 4 sec
Power On !
format logs of lf kg200
detected CPU: MT6226MA
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6219B,E02
Date: 2005.04.12
Version: 1.0
Version: 7S7331IN00-001-R1C
Version: EP1
60 byte(s) read
imei: 35282701257698
connection Ok
building list...
done
items to clear: 218
warning: wrong packet cs
items cleared: 218 of 218
building list...
done
items remains: 0
Finished, time used: 42 sec
Remove/Install battery now !
here is imei rebuild logs
Action: imei
Model: LG-KG200
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
baud set to: 57600
error: connection failed !
operation failed !
Finished, time used: 5 sec
Power off phone now !
Imei 35282701257698 already was repaired: 12/31/2008-6:46:21 PM
Continue with this imei ?
Action: imei
Model: LG-KG200
Connecting, wait...
baud set to: 230400
operation failed !
Finished, time used: 49 sec
Imei 35282701257698 already was repaired: 12/31/2008-6:47:13 PM
Action: imei
Model: LG-KG200
Connecting, wait...
Hardware version: MT6219B, E0
Hardware version: EP1
Software version: 7S7331IN00-001-R1C"
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 135790246811220
imei write method: mode-1
imei write channel: imei #1 for dual sim/mono CPU
new imei: 352827012576989
verification Ok
The Following 2 Users Say Thank You to joni_rajpura For This Useful Post:
Old 12-31-2008, 14:54   #2 (permalink)
kmaxmax's Avatar
Member: 553000
Thanks Meter: 2,302
thnx bro u r doing very well with infinity keep it up nd post ur every log here:
regards
Kmax
Old 12-31-2008, 17:42   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
thank you for sharing your experience!!
Can we know samsung sr no with help of imei ? pavankhatri4024 Samsung Hardware Repair 2 12-02-2009 09:18
Lg Kg300 Format with Pinfinity alfox Infinity-Box 4 07-08-2009 08:26
After format the system with jaf of nokia n70 now no network patelfaizu J.A.F. By Jafsupport.com 11 03-14-2009 08:15
LG C2500 successfull format with Infinity. Shakeel_pattoki Infinity-Box 5 08-17-2008 13:45
C60 battery overheated after flashed with help of testpoint E&D E-Gold Based Phones 0 12-29-2004 17:26
Page generated in 0.16010 seconds with 10 queries
