06-15-2009, 08:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | Lg ke 770 problem(see here) I TRY TO FLASH AND AFTER FLASH I POWER ON THE SET SET SHOW AT SCREEEN BLUETOOTH TEST MODE N RESTARTING WITH KE770 LOGO I FLASH WITH THIS FILE KE770P40-ARB-V10g-000-00_AUG-23-2007_firmware.B1M AFTER FLASH I TRY TO REST SETTING N UNLOCK BUT NOTHING HERE IS A FLASHING LOG COM44 [VCP0] selected module v1.65 Device: LG-KE770 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... reset... done Writing: Firmware Verifying... Done Write Done Finished, time used: 1261 sec Remove/Install battery now ! |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
06-15-2009, 09:07 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: SL3 LBF IN Kamoke(Gujranwala)
Member: 481915 Status: Offline Sonork: 100.1604233 Thanks Meter: 476 | try to reset setting with infinity or flash again with any other firmware here is tested by me many times these firmwares, you can try...........from infinity support phone will be ok: 1- KE770P40-ARB-V10g-000-00_AUG-23-2007_file_system[1].B1S.bin 2- KE770P40-ARB-V10g-000-00_AUG-23-2007_firmware[1].B1M.bin 3- LG-KE770_eeprom-complete_35030526000000100_20081014-110939.B1E.bin Note: 3rd file, i read from working phone now you can download any eeprom from support mianlinks |
06-15-2009, 09:08 | #3 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Islamic Republic Age: 36
Member: 466635 Status: Offline Sonork: 100.1614186 Thanks Meter: 482 | bro this time your phon is on our dead can u tell me here please and flash whit the latest version i think your phon is done whitout any problem b.r sherry mobiles |
06-15-2009, 10:28 | #4 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | Try this Quote:
i try with 3 files but after this set stop at ke700 rest setting but nothing infinty team plz tell me what can i do | |
06-15-2009, 10:51 | #6 (permalink) |
Member: 171512 Status: Offline Thanks Meter: 1,034 | set conditon [QUOTE=InfinitySupport;4564662]Hello, What was happened with phone that it become dead ? Did you checked phone hardware ? i recieve set in dead conditon i flash with 1 file he alive with bkue tooth test mode i flash with 3 files n he stop at ke770 logo what can ido |
06-15-2009, 10:59 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, What was happened with phone that it become dead ? Do you know this phone history ? Did you tried to open phone ? Did you checked phone hardware ? |
04-19-2010, 16:34 | #8 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: DAMMAM Age: 43
Member: 262523 Status: Offline Sonork: 100.1611482 Thanks Meter: 288 | Quote:
flash another file version and check it | |
08-29-2010, 15:36 | #9 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @nk_gsm if you want to advertise your forum I suggest you to make "Infinity-Box" sub-forum at your site, in this case you will be able to advertise your site in Infinity-Box support forum. |
LG KE 770 Power Switch solution ?? | shahzadthe1 | LG Hardware Repair | 3 | 06-19-2012 05:34 |
Lg ke 770 imei change info .. | sajidashraf | Infinity-Box | 3 | 11-18-2009 19:40 |
Lg ke 770 | kash786 | Infinity-Box | 5 | 03-27-2009 07:25 |
LG KE 770 key unlock code How ? | rajumobile | Infinity-Box | 1 | 11-13-2008 16:35 |
lg ke 770 | triyarso | Infinity-Box | 1 | 04-20-2008 20:39 |
