12-19-2008, 18:17 | #1 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 364696 Status: Offline Thanks Meter: 16 | i think team fail to solve 195 shoe "Lg Log" |
12-19-2008, 19:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I am sure it's your fault due to you did not explained the problem well. Please remember that good problem description is 99% of solution. So now think please what to do... |
12-24-2008, 07:57 | #3 (permalink) |
Insane Poster Join Date: Dec 2007
Member: 655795 Status: Offline Thanks Meter: 3 | Brain is right I think brother brain is right because this problem still persist LG kg195 shows logo only and then terns off and whatever you do still the same i have also tried on atleast 4 pieces formate ffs safe mode, formate complete mode, and write whole flash chip. But the problem is still the same 195 shows logo then turns off Infinity team is fail in this problem until now Team should do something |
12-24-2008, 08:10 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. He is not a "brother brain", he is "brother zero brain", it's really serious difference ! 2. You must open phone and check it's hardware carefully before talk about "team should do..." 3. Did you tried to follow he same advice like for KG300 ? I know the answer.... If you REALLY have a problem you must explain the problem well, post logs etc., in other case your words sounds little bit strange, so please, think about this. |
12-25-2008, 18:41 | #5 (permalink) |
Member: 364696 Status: Offline Thanks Meter: 16 | plz look at this og opened: [12/19/2008 2:40:02 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53error: Dongle is not found==== log opened: [12/19/2008 2:40:52 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0111error: Dongle firmware[0111] is out of date (too old) !Download latest "DongleManager" from support area and upgrade dongle firmware !==== log opened: [12/19/2008 2:47:43 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0111error: Dongle firmware[0111] is out of date (too old) !Download latest "DongleManager" from support area and upgrade dongle firmware !==== log opened: [12/19/2008 2:48:49 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0111error: Dongle firmware[0111] is out of date (too old) !Download latest "DongleManager" from support area and upgrade dongle firmware !==== log opened: [12/19/2008 2:59:59 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0111Wait...Device: Aiko 17GDoneDevice: LG KG195Loading file v.02... KG195P64-ARB-V10a-000-00_AUG-08-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001_En_Arabic_Farsi_Ru_Fr.B0M.bin loadedidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001Languages: En Ru Fr Urdu Farsi ArLoading file v.02... KG195_repair_eeprom_01[1].B0E.bin loaded==== log opened: [12/19/2008 4:15:28 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0111Wait...Device: Aiko 17GDoneLoading file v.02... KG195P64-ARB-V10a-000-00_AUG-08-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001_En_Arabic_Farsi_Ru_Fr.B0M.bin loadedidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001Languages: En Ru Fr Urdu Farsi ArLoading file v.02... KG195_repair_eeprom_01[1].B0E.bin loadedCOM1 [Serial0] selectedDevice: Aiko 17GChecking data, wait...advanced flash detection activeAction: write NOR flash"smart write" activewrite: Firmwareskip: Customizationskip: Language Packwrite: EepromBoot...Press and HOLD Power button now !error: can't detect deviceRelease Power button now !in case of initial connection problem: on/off "Boot baudrate autoselect" box.Boot FailFinished, time used: 31 secRemove/Install battery now !COM4 readyCOM4 [VCP0] selectedDevice: Aiko 17GChecking data, wait...advanced flash detection activeAction: write NOR flash"smart write" activewrite: Firmwareskip: Customizationskip: Language Packwrite: EepromBoot...Press and HOLD Power button now !Connecting, wait...Initializing[6226:8A02:8A01]...chip: 0031:F541:8844boot step size: 0400Release Power button now !Boot DoneInitialize...detecting chip #00 in region #00...flash: 98004900000002:29EA0000000000flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mbnumber of flash chip/regions detected: 01/01Initialize DoneSet baud...115200Set baud DoneIdentification...reading [eeprom]...file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20081219-042341.B0E.binIdentification DoneManipulation...Manipulation DoneFinalization...Finalization DoneWrite...Area: Firmwareflash: 98004900000002:29EA0000000000Write: FirmwareArea: Eepromflash: 98004900000002:29EA0000000000Write: EepromWrite DoneFinished, time used: 350 secRemove/Install battery now !==== log opened: [12/19/2008 7:11:07 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0112Wait...Device: LG KG195DoneLoading file v.02... KG195P64-ARB-V10a-000-00_AUG-08-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001_En_Arabic_Farsi_Ru_Fr.B0M.bin loadedidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001Languages: En Ru Fr Urdu Farsi ArLoading file v.02... KG195_repair_eeprom_02[1].B0E.bin loadedWARNING ! Settings will be cleared, user data erased, Imei set to default value !Make flash backup before this procedure !Do you want to continue ?COM4 [VCP0] selectedDevice: LG KG195Checking data, wait...advanced flash detection activeAction: resetBoot...Press and HOLD Power button now !Connecting, wait...Initializing[6226:8A02:8A01]...chip: 0031:F541:8844boot step size: 0400Release Power button now !Boot DoneInitialize...detecting chip #00 in region #00...flash: 98004900000002:29EA0000000000flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mbnumber of flash chip/regions detected: 01/01Initialize DoneSet baud...115200Set baud DoneIdentification...detect device identification#1...detection phase #1...detect device identification#1 finishedidentification#1 structure: 2nd [standard] (or higher) generationidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001ffs offset/size: 00E00000/00200000detect device identification#2...detection phase #1....warning: optional information not founddetect device identification#2 finishedreading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]]...error: unexpected data: 150000002215000000BA15000000BA1500000058C13Bwarnin g: wrong data size at 0x00E12000, retry...warning: wrong data size at 0x00E12000, retry...warning: wrong data size at 0x00E12000, retry...file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]_20081219-071627.A3E.binerror: no any expected answererror: no any expected answer: wrong answer after chip id requesterror: no any expected answererror: no any expected answererror: no any expected answer: wrong answer after chip cfi requesterror: no any expected answererror: no any expected answer: wrong answer after chip id requestIdentification FailFinished, time used: 56 secRemove/Install battery now !==== log opened: [12/19/2008 7:17:38 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0112Wait...Device: Aiko 17GDone==== log opened: [12/19/2008 7:26:11 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53error: Dongle is not found==== log opened: [12/19/2008 8:14:23 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0112Wait...Device: LG-KG195DoneLoading file v.02...KG195_repair_eeprom_02[1].B0E.bin loaded==== log: [12/19/2008 8:15:09 AM] ====COM4 [VCP0] selectedmodule v2.53Device: LG-KG195Checking data, wait...advanced flash detection enabledAction: write NOR flash"smart write" activeskip: Firmwareskip: Customization/Language Packskip: Customizationwrite: Eeprom/ffseeprom backup enabled, it may takes several minutes !Boot ...Press and HOLD Power button now !19200 fixedConnecting, wait...Initializing [6226:8A02:8A01]...CPU: MT6226chip: 0031:F541:8844boot packet size: 0400Release Power button now !Boot DoneInitialize ...detecting chip #00 in region #00...flash: 98004900000002:29EA0000000000flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mbnumber of flash chip/regions detected: 01/01Initialize DoneSet baud ...115200Set baud DoneInitialize bootcode ...Initialize bootcode DoneCheck firmware integrity ...detect device identification#1...detection phase #1...detect device identification#1 finishedidentification#1 structure: 2nd [standard] generationidentification#1 protocol ver: 04ver. sw 1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw 2: 7S7332SA00-001, 00000000ffs offset/size: 00E00000/00200000detect device identification#2...detection phase #1....warning: optional information is not found,if phone works well just ignore this warningdetect device identification#2 finishedsim-lock status: unknownCheck firmware integrity DoneCheck firmware content ...Check firmware content DoneBackup required data ...reading: eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]...file saved: C:\Program Files\InfinityBox\MModule\eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]_20081219-081921.B0E.binBackup required data DonePatch required data ...Patch required data DoneSpecial operation ...Special operation DoneWrite ...Area: Eeprom/ffsflash: 98004900000002:29EA0000000000Write: Eeprom/ffsdetect device identification#2...detection phase #1....warning: optional information is not found,if phone works well just ignore this warningdetect device identification#2 finishedWrite DoneFinalization ...Finalization DoneFinished, time used: 445 secRemove/Install battery now !==== log: [12/19/2008 8:50:09 AM] ====COM4 [VCP0] selectedmodule v2.53Action: imeiimei write method: mode-2imei write channel: imei #1 for dual sim/mono CPUnew imei: 356733010912596Model: LG-KG195Checking data, wait...Phone should be Switched OFF !Press and HOLD Power button now !19200 autodetectInitializing [6226:8A02:8A01]...CPU: MT6226chip: 0031:F541:8844Connecting, wait...Release Power button now !Phone detected, wait...Hardware: MT6226,E02Date: 2005.04.12Version: 1.0Version: 7S7332SA00-001Version: FP_062060 byte(s) readimei: 35673301279257connection Ok60 byte(s) readverification...verification done: 35673301091259Finished, time used: 11 secRemove/Install battery now ! |
12-25-2008, 18:45 | #6 (permalink) |
Member: 364696 Status: Offline Thanks Meter: 16 | og opened: [12/19/2008 2:40:02 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53error: Dongle is not found==== log opened: [12/19/2008 2:40:52 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0111error: Dongle firmware[0111] is out of date (too old) !Download latest "DongleManager" from support area and upgrade dongle firmware !==== log opened: [12/19/2008 2:47:43 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0111error: Dongle firmware[0111] is out of date (too old) !Download latest "DongleManager" from support area and upgrade dongle firmware !==== log opened: [12/19/2008 2:48:49 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0111error: Dongle firmware[0111] is out of date (too old) !Download latest "DongleManager" from support area and upgrade dongle firmware !==== log opened: [12/19/2008 2:59:59 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0111Wait...Device: Aiko 17GDoneDevice: LG KG195Loading file v.02... KG195P64-ARB-V10a-000-00_AUG-08-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001_En_Arabic_Farsi_Ru_Fr.B0M.bin loadedidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001Languages: En Ru Fr Urdu Farsi ArLoading file v.02... KG195_repair_eeprom_01[1].B0E.bin loaded==== log opened: [12/19/2008 4:15:28 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0111Wait...Device: Aiko 17GDoneLoading file v.02... KG195P64-ARB-V10a-000-00_AUG-08-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001_En_Arabic_Farsi_Ru_Fr.B0M.bin loadedidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001Languages: En Ru Fr Urdu Farsi ArLoading file v.02... KG195_repair_eeprom_01[1].B0E.bin loadedCOM1 [Serial0] selectedDevice: Aiko 17GChecking data, wait...advanced flash detection activeAction: write NOR flash"smart write" activewrite: Firmwareskip: Customizationskip: Language Packwrite: EepromBoot...Press and HOLD Power button now !error: can't detect deviceRelease Power button now !in case of initial connection problem: on/off "Boot baudrate autoselect" box.Boot FailFinished, time used: 31 secRemove/Install battery now !COM4 readyCOM4 [VCP0] selectedDevice: Aiko 17GChecking data, wait...advanced flash detection activeAction: write NOR flash"smart write" activewrite: Firmwareskip: Customizationskip: Language Packwrite: EepromBoot...Press and HOLD Power button now !Connecting, wait...Initializing[6226:8A02:8A01]...chip: 0031:F541:8844boot step size: 0400Release Power button now !Boot DoneInitialize...detecting chip #00 in region #00...flash: 98004900000002:29EA0000000000flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mbnumber of flash chip/regions detected: 01/01Initialize DoneSet baud...115200Set baud DoneIdentification...reading [eeprom]...file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20081219-042341.B0E.binIdentification DoneManipulation...Manipulation DoneFinalization...Finalization DoneWrite...Area: Firmwareflash: 98004900000002:29EA0000000000Write: FirmwareArea: Eepromflash: 98004900000002:29EA0000000000Write: EepromWrite DoneFinished, time used: 350 secRemove/Install battery now !==== log opened: [12/19/2008 7:11:07 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0112Wait...Device: LG KG195DoneLoading file v.02... KG195P64-ARB-V10a-000-00_AUG-08-2007_ARIMA26_05C_PCB01_GPRS_MT6226_S01[1].7S7332SA00-001_En_Arabic_Farsi_Ru_Fr.B0M.bin loadedidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001Languages: En Ru Fr Urdu Farsi ArLoading file v.02... KG195_repair_eeprom_02[1].B0E.bin loadedWARNING ! Settings will be cleared, user data erased, Imei set to default value !Make flash backup before this procedure !Do you want to continue ?COM4 [VCP0] selectedDevice: LG KG195Checking data, wait...advanced flash detection activeAction: resetBoot...Press and HOLD Power button now !Connecting, wait...Initializing[6226:8A02:8A01]...chip: 0031:F541:8844boot step size: 0400Release Power button now !Boot DoneInitialize...detecting chip #00 in region #00...flash: 98004900000002:29EA0000000000flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mbnumber of flash chip/regions detected: 01/01Initialize DoneSet baud...115200Set baud DoneIdentification...detect device identification#1...detection phase #1...detect device identification#1 finishedidentification#1 structure: 2nd [standard] (or higher) generationidentification#1 protocol ver: 04ver. sw1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw2: 7S7332SA00-001ffs offset/size: 00E00000/00200000detect device identification#2...detection phase #1....warning: optional information not founddetect device identification#2 finishedreading [eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]]...error: unexpected data: 150000002215000000BA15000000BA1500000058C13Bwarnin g: wrong data size at 0x00E12000, retry...warning: wrong data size at 0x00E12000, retry...warning: wrong data size at 0x00E12000, retry...file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]_20081219-071627.A3E.binerror: no any expected answererror: no any expected answer: wrong answer after chip id requesterror: no any expected answererror: no any expected answererror: no any expected answer: wrong answer after chip cfi requesterror: no any expected answererror: no any expected answer: wrong answer after chip id requestIdentification FailFinished, time used: 56 secRemove/Install battery now !==== log opened: [12/19/2008 7:17:38 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v1.70S/N: 29CB:0112Wait...Device: Aiko 17GDone==== log opened: [12/19/2008 7:26:11 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53error: Dongle is not found==== log opened: [12/19/2008 8:14:23 AM] ====Application: C:\Program Files\InfinityBox\MModule\MModule.exeLoading data, wait...[Infinity Box] v2.53S/N: 29CB:0112Wait...Device: LG-KG195DoneLoading file v.02...KG195_repair_eeprom_02[1].B0E.bin loaded==== log: [12/19/2008 8:15:09 AM] ====COM4 [VCP0] selectedmodule v2.53Device: LG-KG195Checking data, wait...advanced flash detection enabledAction: write NOR flash"smart write" activeskip: Firmwareskip: Customization/Language Packskip: Customizationwrite: Eeprom/ffseeprom backup enabled, it may takes several minutes !Boot ...Press and HOLD Power button now !19200 fixedConnecting, wait...Initializing [6226:8A02:8A01]...CPU: MT6226chip: 0031:F541:8844boot packet size: 0400Release Power button now !Boot DoneInitialize ...detecting chip #00 in region #00...flash: 98004900000002:29EA0000000000flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mbnumber of flash chip/regions detected: 01/01Initialize DoneSet baud ...115200Set baud DoneInitialize bootcode ...Initialize bootcode DoneCheck firmware integrity ...detect device identification#1...detection phase #1...detect device identification#1 finishedidentification#1 structure: 2nd [standard] generationidentification#1 protocol ver: 04ver. sw 1: ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BINver. sw 2: 7S7332SA00-001, 00000000ffs offset/size: 00E00000/00200000detect device identification#2...detection phase #1....warning: optional information is not found,if phone works well just ignore this warningdetect device identification#2 finishedsim-lock status: unknownCheck firmware integrity DoneCheck firmware content ...Check firmware content DoneBackup required data ...reading: eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]...file saved: C:\Program Files\InfinityBox\MModule\eeprom[ARIMA26_05C_PCB01_GPRS_MT6226_S01.7S7332SA00-001.BIN]_20081219-081921.B0E.binBackup required data DonePatch required data ...Patch required data DoneSpecial operation ...Special operation DoneWrite ...Area: Eeprom/ffsflash: 98004900000002:29EA0000000000Write: Eeprom/ffsdetect device identification#2...detection phase #1....warning: optional information is not found,if phone works well just ignore this warningdetect device identification#2 finishedWrite DoneFinalization ...Finalization DoneFinished, time used: 445 secRemove/Install battery now !==== log: [12/19/2008 8:50:09 AM] ====COM4 [VCP0] selectedmodule v2.53Action: imeiimei write method: mode-2imei write channel: imei #1 for dual sim/mono CPUnew imei: 356733010912596Model: LG-KG195Checking data, wait...Phone should be Switched OFF !Press and HOLD Power button now !19200 autodetectInitializing [6226:8A02:8A01]...CPU: MT6226chip: 0031:F541:8844Connecting, wait...Release Power button now !Phone detected, wait...Hardware: MT6226,E02Date: 2005.04.12Version: 1.0Version: 7S7332SA00-001Version: FP_062060 byte(s) readimei: 35673301279257connection Ok60 byte(s) readverification...verification done: 35673301091259Finished, time used: 11 secRemove/Install battery now ! |
12-25-2008, 19:21 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, To be honest it's quite hard to understand this kind of logs. Could you, please, post log in more readable format. Thank you very much for your kind help ! |
12-25-2008, 19:54 | #8 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
Failed to write imei..????? | sky_finder | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-30-2010 15:45 |
mxkey team how to solve this prb..- WD timer enabled, phone will reboot itself after | mobispot | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-28-2010 21:35 |
nff team hlp to solve asic 11 | narangmoga | Nokia Fault Finder Box | 4 | 11-18-2008 08:12 |
infenity is failed to solve bad software | Maiwand khan | Infinity-Box | 6 | 08-11-2008 23:21 |
to Andru:-i think only you can solve my griffin box | alnasser | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 05-15-2003 11:17 |
