12-25-2008, 08:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | lg ke 970 problem COM5 [VCP0] selected module v1.57 Device: LG-KE970 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! loading... next part... error: can't run main loader: Finished, time used: 16 sec Remove/Install battery now ! is it hardware problem ? |
12-25-2008, 18:42 | #3 (permalink) |
Member: 184351 Status: Offline Thanks Meter: 263 | sorry infinity the problem in this phone is that i have flashed it many times using infinity because it was in blinking state and freezing in lg logo but he became dead he was accepting flash normally but he stays dead so i decided to try with hwk but it fails in erasing it after that i used infinity software again and this problem appears error: can't run main loader so what do you think even after changing latency always the same error i think hwk destroyed something in the phone booting block |
12-25-2008, 18:48 | #4 (permalink) | |
Junior Member Join Date: Nov 2008 Location: Pir Mahal
Member: 902419 Status: Offline Thanks Meter: 1 | Quote:
we r many cellphone unlock Ke970 100% by infinity.but ur matters , idnt know . cnange u PC and cable. INFINTY deals suporter LG models best than other bro | |
12-25-2008, 19:19 | #5 (permalink) |
Member: 184351 Status: Offline Thanks Meter: 263 | yes i know that infinity supports lg phones very good but i suspect hardware issue and my question was if hwk has destoryed the booting block in the phone because the problem appears after using hwk |
12-25-2008, 19:24 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I do not know is this option available in HWK, but if you can post here HWK log text please, post it here so we will be able to check it. How many % of flash was erased/flashed with HWK ? |
12-25-2008, 19:28 | #7 (permalink) |
Member: 184351 Status: Offline Thanks Meter: 263 | sorry i did not save the log and now the phone wont accept to connect with hwk also but it erased 0% and said erasing fail (no any advancement) |
12-25-2008, 19:38 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Yes, you are right, if it was problems at 0% it may be problem with boot area. To be honest I have no any good advice right now, need some time to check situation more carefully, |
lg ke 970 flashing problem | amirkaaal | VygisToolbox | 5 | 01-11-2009 15:06 |
streng problem with LG KE-970 | imranieman | LG | 0 | 06-09-2008 19:52 |
Help!Problem with lg ke 970 unlock! | med_ion | VygisToolbox | 8 | 05-03-2008 16:44 |
LG KE 970 problem | starcell | LG | 0 | 03-04-2008 23:22 |
lg ke 970 imei 000000000000000 | elkom | ULT PRO | 0 | 08-28-2007 13:59 |
