lg ke770(Telstra) not conect with infinity i try to remove user lock of lg ke770(testra)and i conect it with kg800 infinity cable.i try to dedecet the mobile with infinity .i try every thing iinstall and remove bettry and hold power on but infinity not dedect the set.plz help me COM3 [VCP1] selected Device: LG-KE770 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! |
Hello, I think it may be only one problem: damaged cable or damaged phone connector. Please, double check cable and connector and try again. |
Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) http://www.infinity-box.biz/download...shell_v112.jpg Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
How about to see DOCUMENTATION page in Shell ? http:///www.infinity-box.com/downloa...ation_page.jpg |
Hello, Ok, this time please check attached picture, you can see box RJ45 connector pinout. |
Infinity unlock ok KE770 Telstra, thanks Infinity team Quote:
Cable name: LG-KG800 keyboard top 1.........18 12: Box Tx/Phone Rx (RJ45 pin-2) 13: Box Rx/Phone Tx (RJ45 pin-3) 18: Gnd If you still can not understand what to do please, explain exactly what you can not understand. |
Yes, now I understand what you need ! Sorry that I was so stupid and did not provide good solution before ! Here is detailed instruction for you: 1. here is box RJ45 picture: http://forum.gsmhosting.com/vbb/show...67&postcount=6 2. here is phone pinout: keyboard top 1.........18 12: Box Tx/Phone Rx (RJ45 pin-2) 13: Box Rx/Phone Tx (RJ45 pin-3) 18: Gnd Now just connect phone contacts to box contacts and unlock phone in seconds. If you still have any problems please, explain what is the problem exactly so we will be able to give you more advices. |
3 Attachment(s) Quote:
Hello, Is it any kind of joke or anything else ? if you really can not understand how to make cable according to my previous explanation I strongly suggest you to learn more about wires, cables, phones and other things. In other case this job is not for you due to you will kill many phones before you will get first result. Let me think that it just your bad joke and you just want to check how is strong our support with this kind of customers like you so I will be very patiend and here is explanation for babies (who must not repair any phone to avoid dead device): 1. look at your connector picture. top contact is RJ45 pin-1, 2nd from top is RJ45 pin-2, 3rd from top is RJ45 pin-3 etc..., last contact for top (means first from bottom) is RJ45 pin-8. I hope now you can understand how to calculate pins. 2. connect GND (RJ45 pin-7) to phone pin 18 3. connect RJ45 pin-2 to phone pin 12 4. connect RJ45 pin-3 to phone pin 13 Cable is ready. Oh... I forgot one more important thing. how to calculate phone pins. Here is instruction how to calculate it: keyboard top 1.........18 put phone on table (if you have it) or somewhere else this way: phone connector near you. phone keyboard should be at top (this means keyboard is NOT at table, this means that phone battery is at table). Now start to calculate pins from left to right. I hope you know where is LEFT, but anyway here is an explanation: Here is LEFT.......................................here is RIGHT so count pins from LEFT to RIGHT this way: 1 is here, 2 is here ---->--->---> 18 is here. Please, confirm, is it enough clear explanation ? Also I hope you can understand why you have ignored my previous link with detailed explanation how to build cable. P.S. I stronlgy suggest you to buy PinFinder adapter due to PinFinder adapter can detect pinout automatically. For sure it's the best choice for people who don't know how to build cables. |
