Old 11-30-2008, 05:31   #1 (permalink)
Member: 383211
Thanks Meter: 99
lg ke770(Telstra) not conect with infinity
i try to remove user lock of lg ke770(testra)and i conect it with kg800 infinity cable.i try to dedecet the mobile with infinity .i try every thing iinstall and remove bettry and hold power on but infinity not dedect the set.plz help me
COM3 [VCP1] selected
Device: LG-KE770
Checking data, wait...
Action: reset
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
The Following User Says Thank You to pakmobiles For This Useful Post:
Old 11-30-2008, 13:23   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
I think it may be only one problem: damaged cable or damaged phone connector.
Please, double check cable and connector and try again.
Old 11-30-2008, 13:45   #3 (permalink)
Member: 383211
Thanks Meter: 99
Originally Posted by InfinitySupport View Post
Hello,
plz send me cable pinout if possible give me with cable pic bcoz i m new with cable creating
Old 11-30-2008, 13:51   #4 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable: http:///vbb/showthread.php?t=342807
Old 12-01-2008, 09:59   #5 (permalink)
Member: 383211
Thanks Meter: 99
Hello,
Here is information how to build your own cable: F.A.Q., Contacts, Supported models, Cables/pinouts
i read ur instraction carefully.i try my best.in creat a cable if i wrong joint rx,tx and gnd then the mobile or box are working or not bcoz in rx and tx i m not sure .and in my cable colure is defrent like wite red green black.i m confuse about where i start the joint the cable .from left of conector or right of conector.plz help me
Old 12-01-2008, 14:17   #6 (permalink)
Member: 130995
How about to see DOCUMENTATION page in Shell ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 12-02-2008, 06:01   #7 (permalink)
Member: 383211
Thanks Meter: 99
i only check the link u sent to me.
Old 12-02-2008, 11:02   #8 (permalink)
Member: 130995
Hello,
Ok, this time please check attached picture, you can see box RJ45 connector pinout.
Old 12-03-2008, 03:26   #9 (permalink)
Crazy Poster
Member: 254444
Thanks Meter: 3
Infinity unlock ok KE770 Telstra, thanks Infinity team
==== log: [12/3/2008 8:40:21 AM] ====
COM5 [VCP0] selected
Device: LG-KE770
Action: unlock
direct unlock
Boot...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0089:88B0
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta_20081203-084110.B1E.bin
reading [eeprom-sta2]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sta2_20081203-084113.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading [eeprom-sec_35030526000000100]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-sec_35030526000000100_20081203-084116.B1E.bin
reading [eeprom-complete_35030526000000100]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE770_eeprom-complete_35030526000000100_20081203-084121.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
Erasing: eeprom-complete
Writing: eeprom-complete
Verifying...
Verify result: 01E2
Done
probably you need to restore original imei after unlock process
Write Done
Finished, Remove/Install battery now !
Time used: 61 sec
The Following User Says Thank You to Yuris_revenge For This Useful Post:
Old 12-03-2008, 05:46   #10 (permalink)
Member: 383211
Thanks Meter: 99
Hello,
ok i ckeck it the box pinout.yesterday i spend whole day but i never secseed.plz sent me the specific picture of kg800 pinout with cable.i m very thankful to u.
Old 12-03-2008, 17:33   #11 (permalink)
Member: 130995
Cable name: LG-KG800
keyboard top
1.........18
12: Box Tx/Phone Rx (RJ45 pin-2)
13: Box Rx/Phone Tx (RJ45 pin-3)
18: Gnd
If you still can not understand what to do please, explain exactly what you can not understand.
Old 12-04-2008, 05:22   #12 (permalink)
Member: 383211
Thanks Meter: 99
keyboard top
1.........18
18: Gnd
i mean i don.t understand about conector how i joint rx.tx and gnd on what pin.simply i want that u sent me the conecter with cable picture there i see that where i joint the cable pinout
Old 12-04-2008, 12:25   #13 (permalink)
Member: 130995
Yes, now I understand what you need !
Sorry that I was so stupid and did not provide good solution before !
Here is detailed instruction for you:
1. here is box RJ45 picture: lg ke770(Telstra) not conect with infinity
2. here is phone pinout:
keyboard top
1.........18
18: Gnd
Now just connect phone contacts to box contacts and unlock phone in seconds.
If you still have any problems please, explain what is the problem exactly so we will be able to give you more advices.
Old 12-05-2008, 16:18   #14 (permalink)
Member: 383211
Thanks Meter: 99
keyboard top
1.........18
18: Gnd
i m thankful to u.u guide me very well but i m don,t know about hardware or making cable.u sent me link for my salution but when i go to link there is on pic which is not desplay.i sent u three pics .one is the phone and conector and second is only conect and third is rj45 cable.u see it and edit it whith where join rx,txand gnd.i my mind i thing the red in rj45 on pin 2 and white is in rj45 on 3 pin and gnt is black snd green in rj45 7and 8.but i don,t know the driction to join the cable pin out.please sent me suport through this pics.thanks in advance.
Old 12-05-2008, 17:44   #15 (permalink)
Member: 130995
Hello,
Is it any kind of joke or anything else ?
if you really can not understand how to make cable according to my previous explanation I strongly suggest you to learn more about wires, cables, phones and other things. In other case this job is not for you due to you will kill many phones before you will get first result.
Let me think that it just your bad joke and you just want to check how is strong our support with this kind of customers like you so I will be very patiend and here is explanation for babies (who must not repair any phone to avoid dead device):
1. look at your connector picture.
top contact is RJ45 pin-1, 2nd from top is RJ45 pin-2, 3rd from top is RJ45 pin-3 etc..., last contact for top (means first from bottom) is RJ45 pin-8.
I hope now you can understand how to calculate pins.
2. connect GND (RJ45 pin-7) to phone pin 18
3. connect RJ45 pin-2 to phone pin 12
4. connect RJ45 pin-3 to phone pin 13
Cable is ready.
Oh... I forgot one more important thing. how to calculate phone pins.
Here is instruction how to calculate it:
keyboard top
1.........18
put phone on table (if you have it) or somewhere else this way: phone connector near you. phone keyboard should be at top (this means keyboard is NOT at table, this means that phone battery is at table). Now start to calculate pins from left to right.
I hope you know where is LEFT, but anyway here is an explanation:
Here is LEFT.......................................here is RIGHT
so count pins from LEFT to RIGHT this way:
1 is here, 2 is here ---->--->---> 18 is here.
Please, confirm, is it enough clear explanation ?
Also I hope you can understand why you have ignored my previous link with detailed explanation how to build cable.
P.S.
I stronlgy suggest you to buy PinFinder adapter due to PinFinder adapter can detect pinout automatically. For sure it's the best choice for people who don't know how to build cables.
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
infiniti box can not conect with mobile shoaib82a Infinity-Box 2 11-12-2008 11:59
LG C3300 not success with INFINITY green bird Infinity-Box 3 07-25-2007 19:51
w375 not conected via infinity tool bobjani2005 Infinity-Box 2 05-11-2007 12:13
c118 select flash files mistake now can not conect with soft and dead leroi Infinity-Box 2 07-03-2006 21:18
A55 not conect with pc zoki Phone Unlocking Codes & Maps 1 12-15-2003 08:36
Page generated in 0.50311 seconds with 9 queries
