LG KE850 unlock problem Hi, Please help after unlocking phone, when power on, it shows "Insert Right Sim Card" Could it be IMEI / eeprom problem as the value does not match the IMEI at the back. However, the phone was working before unlock. Here is the log. COM9 [VCP0] selected Device: LG KE850 Checking data, wait... Action: unlock Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080421-125414.B1E.bin reading [eeprom-sta2]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-sta2_20080421-125416.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080421-125418.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: E:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080421-125420.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 01D5 Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 20 sec |
any help here please? |
Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Repair imei... software version: KE850P40-852-V10h-***-XX MAY 17 2007+0 original imei: 3534260135****600 new imei: 3534260135**** Done Finished |
is the phone something counter blocked or such thing |
what do you mean by that? Any way to chat over msn or something? Thanks |
Product Supporter/ Infiniti Team, Need help please. Waiting to long already. Thanks |
we are working on your problem , give us some time |
Thank you for the reply. Best Regards. |
There is no any problems with unlock process, in some cases you just need to flash phone instead of wait several days. Don't forget to make flash backup for emergency case. |
hello i have the same problem with ke850. after flashing it with KE850CP40-7-V10i-***-XX_JAN-19-2008_firmware.B1M KE850CP40-7-V10i-***-XX_JAN-19-2008_file_system.B1S i get this message "Insert Sim Card" i have tried to write eeprom but still no luck for me i have tried to flash with vigys also but its the same problem. is there any good solution for this problem? |
Is it problem with unlock or another problem ? |
after flashing the phone i get this message "Insert Sim Card" although the sim card is inside. It`s not a hardware problem because the phone was working before i have flashed it. I`ve tried to flash it with different flash files but i havent been succesfull. i`ve tried to flash the eeprom too but again i was not succesfull. Finaly i have flashed it with VIGYS box and everything was fine I wonder what is the problem with Infinity box? |
@talat There is no problem with Infinity-Box, the only problem is that we did not had that flash file that was suitable for your phone. We will be glad to get more flash backup files so we will be able to upload it in support area for all users: [email protected] |
@ Product Supporter. Can you tell me why it is very difficult to re-write back IMEI? Sometimes can write, but when come to verify, it says errror. At other times, i get this error report Phone must be SWITCHED ON ! Connecting, wait... Connection Fail Finished I am using Original USB cable (no modifications) plugged to an adaptor to Infiniti box. Thanks |
