05-08-2008, 11:00 | #16 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: next to you ; ) Age: 54
Member: 1133 Status: Offline Thanks Meter: 38 | Quote:
Product Supporter, Please do not forget to reply. TQ. | |
05-08-2008, 15:06 | #17 (permalink) | |
How about to use cable that should be used instead of cable that you have (do you see the difference) ? Please, run Infinity-Box Shell, select required model and see detailed information about cable/pinout. Also, be sure that yor phone is POWERED-ON and LCD is not black (phone is NOT in sleep mode). | |
05-09-2008, 03:08 | #18 (permalink) | |
It is only when I keep the phone on for IMEI change, I get fail message.I have also tried to keep phone in suspend mode by pressing keypad just to keep lights on but still fail. Could it be that the Original Cable is too long for the Infiniti box? Thanks | |
05-10-2008, 07:02 | #21 (permalink) | |
Is it unlocked or locked ? Is it problem with imei or any other problem ? As I can see from this thread you have tried many things so it's need to know what is the problem now. | |
05-10-2008, 08:49 | #22 (permalink) | |
State of phone is still locked. I have been adviced to flash phone, unlock and re-write IMEI but all this still does not work. Thanks, | |
05-10-2008, 08:55 | #23 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | 1. flash phone with the next files: KE850CP40-7-V10i-***-XX_JAN-19-2008_firmware.B1M.bin KE850CP40-7-V10i-***-XX_JAN-19-2008_file_system.B1S.bin What you see at phone LCD after you power-on phone WITHOUT SIM card ? What you see at phone LCD after you power-on phone WITH SIM card ? What is the imei ? |
05-13-2008, 09:22 | #24 (permalink) | |
Hi, After using your described version, the phone is unlocked. However, the phone came with Chinese Language, but it is not Russian. Can we do something about it? I'll be most glad to send you the Original Chinese Flash if you need it. Thanks for all the help. Great Team. | |
05-13-2008, 14:19 | #25 (permalink) | |
Sorry, I don't understand well: do you need to make this phone with Chinese language or with Russian ? We have no flash files for KE850 with Chinese language in support area. If you need to see Chinese files in support area please, send Chinese original files to [email protected] or upload it to rapidshare.com | |
05-13-2008, 21:51 | #26 (permalink) | |
Yes, I have a Chinese Version backup but it is sim-locked. It's the same version i described earlier on this post that cannot be unlocked until I used the verson you dscribed. KE850CP40-7-V10i-***-XX_JAN-19-2008_firmware.B1M.bin KE850CP40-7-V10i-***-XX_JAN-19-2008_file_system.B1S.bin Is that ok? | |
lg ke850 sim problem | MOBO12DZ | LG | 6 | 11-06-2014 13:47 |
LG KE850 unlock | RodolfoR | PolarBox 3 | 0 | 06-10-2008 12:57 |
ke850 unlock problem | alex1205 | FuriousGold | 3 | 11-21-2007 13:07 |
KE850 Unlock problem after flash | jodge | VygisToolbox | 12 | 09-05-2007 06:14 |
KE850 unlock problem | roberts | FuriousGold | 2 | 08-22-2007 13:29 |
