Old 08-03-2008, 13:50   #1 (permalink)
Member: 677958
LG KE970 chang imei
hi. how to change imie lgke970.conect with cable kg800 and read flash but when push tik for write change imei(SWICHE ON)conect file.pleas help me
Old 08-03-2008, 18:35   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Phone should be Powered-On
Connect cable and press \"write\" button
Old 08-04-2008, 07:20   #3 (permalink)
Member: 677958
hi.i do.phone powered on .conect cable and press write but not conect
Old 08-04-2008, 08:13   #4 (permalink)
..::: Naveed :::..'s Avatar
Member: 352237
Sonork: 100.1577161
Thanks Meter: 605
Check your cable
Naveed
Old 08-04-2008, 09:10   #5 (permalink)
Member: 677958
hi. cable is ok,i doing read flash and unlock.
Old 08-04-2008, 09:52   #6 (permalink)
Member: 70652
Thanks Meter: 2
I'am facing the same problem include "Read Information", perhaps infinity support team should recheck it, maybe litlle bug with "pana01 ver1.51."
"Reset to default" ok
"Read flash" ok
Old 03-17-2009, 17:45   #7 (permalink)
Member: 447849
Sonork: 100.1604076
Thanks Meter: 593
Same Problem with me
please help infinity team
i am using pana01 1.64
but still same problem
almost all functions are working perfect with my cable
but when i do change imei then phone will not connect
B.r.,
sonu
Old 12-02-2009, 18:26   #8 (permalink)
Registered User
Member: 55026
Thanks Meter: 53
I use ver 1.71 but the problem still the same!! Unlock OK, Read/Write Flash OK but Action when phone is POWERED ON not working absolutelly! like Read phone info and Repair IMEI.
COM4 [VCP1] selected
module v1.71
Device: LG-KE970
Checking data, wait...
Action: unlock
direct unlock
Boot ...
s-gold2: C0
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
460800
Set Baud Done
Connecting ...
flash: 0089:88B0
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static_20091202-192228.B1E.bin
reading eeprom-static2...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-static2_20091202-192228.B1E.bin
loading data...
data loaded
imei: 35030526000000100
reading eeprom-security_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20091202-192230.B1E.bin
reading eeprom-complete_35030526000000100...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20091202-192231.B1E.bin
backup critical area Done
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-complete
Writing: eeprom-complete
Verifying...
Verify result: 013E
Done
probably you need to restore original imei after unlock process
Write Done
Finished, time used: 62 sec
Remove/Install battery now !
lg b2050 chang imei RaSkAl01 Infinity-Box 3 05-22-2008 08:02
LG 8120 change imei error VIZER Cruiser Suite 9 10-28-2005 15:34
lg g7020 Change imei cowvsboy Blazer 1 09-29-2004 16:45
lg g5220c change imei? nvr_wizard LG 0 07-20-2004 08:57
lg w510 change imei Trophy LG 0 04-08-2003 17:06
Page generated in 0.23237 seconds with 9 queries
