07-10-2009, 22:36 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: United States Age: 50
Member: 259133 Status: Offline Thanks Meter: 22 | Lg ke970 flash problem i am trying to flash this phone to change the language, i want spanish in it, but i flashed with KE970P40-07-V10e-000-00_APR-05-2007_firmware_En_Ee_Kz_Lv_Lt_Ru_Ua.B1M irst, but i dont understand to change to spanish with this one, after that i downloaded this other one KE970P40-ESA-V10f-000-00_MAY-15-2007_En_Vn_firmware.B1M but the same comes the message "meni" for menu, i dont know what language is this and cant not change it, here is the last flash log COM4 [VCP0] selected module v1.60 Device: LG-KE970 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 02 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0089:88B0 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-static_20090710-164912.B1E.bin reading eeprom-static2... file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-static2_20090710-164912.B1E.bin loading data... data loaded imei: 35030526000000100 reading eeprom-security_35030526000000100... file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-security_35030526000000100_20090710-164913.B1E.bin reading eeprom-complete_35030526000000100... file saved: F:\Archivos de programa\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20090710-164914.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Writing: Firmware repair write error [A06F4000:0800]... Ok Verifying... Done Write Done Finished, time used: 1122 sec Remove/Install battery now ! |
07-11-2009, 10:31 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to browse menu and find menu with Language option. Also you can try to use codes http://www.infinity-box.com/wiki/index.php/LG-KG110 and reset phone, so language should be set to English. |
07-11-2009, 19:52 | #3 (permalink) | |
Member: 259133 Status: Offline Thanks Meter: 22 | Quote:
11-30-2011, 02:02 | #4 (permalink) |
Freak Poster Join Date: Nov 2011
Member: 1698387 Status: Offline Thanks Meter: 43 | Hello Infinty team I have LG KE970 I have made full flash backup first and than tried to flash it whit an other firmware from support site. In flash process i had problems whit my computer and it made a reboot. After i fixed the computer and tried to flash phone again it always giving me this error. Now the phone cannot power on. Please help me Thank you COM4 [VCP0] selected module v1.77 Device: LG-KE970 Checking data, wait... Action: write flash write: Firmware KE970P40FL-48-V10c-260-01_DEC-20-2007+0.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 6 sec Remove/Install battery now ! |
12-05-2011, 01:43 | #8 (permalink) | |
Member: 1698387 Status: Offline Thanks Meter: 43 | Quote:
Would you please help me whit this KE970? OM4 [VCP0] selected module v1.77 Device: LG-KE970 Checking data, wait... Action: write flash write: Firmware KE970P40FL-48-V10c-260-01_DEC-20-2007+0.B1M.bin skip: FFS-1/Customization skip: Language Pack skip: Graphics Pack skip: FFS-2/File system skip: Eeprom Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... next part... error: can't run main loader: Finished, time used: 6 sec Remove/Install battery now ! | |
12-06-2011, 23:59 | #10 (permalink) | |
I have tried many times. i did pressed the power button long enough. The battery has 3.78Volts right now. Lett me tell you what is the history of this phone. The phone was working fine before this procedure only had freeze problem when i enter to file manager. I made a format ffs on the phone but problem is not fixed. After this i have downloaded firmware and eeprom files from server and start to flash it. This time my computer is turn off by a power break at are building. (before flashing is finished) Than this problem is came up. I also have the full flash backup but now the phone is dead and cannot flash it back. I have searched some of forums and have find that many people has same problem and they did not find any solution. Would you please help me or do you have any idea what to do? Thank you | |
12-09-2011, 15:58 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, seems that your phone boot sector is damaged now. we have some recovery ideas for such cases, will focus on them after will finish with current work |
lg LG KE970 KEYPAD PROBLEM | oyinkasola | LG Hardware Repair | 1 | 07-15-2009 23:42 |
Fine for LG KE970 Flash Tool and Flash File | Khmer GSM | LG | 1 | 01-01-2009 11:47 |
LG-KE970 Flashing Problem | JaY'Treze | Infinity-Box | 17 | 12-03-2008 17:37 |
LG KE970 Flash Problem | imran_qasim | Infinity-Box | 3 | 08-29-2008 19:20 |
lg KE970 unlock problem | oss001 | LG | 1 | 12-24-2007 12:48 |
