05-07-2008, 19:40 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 438 | ..:: ** CPU Indentify - Pin Finder ** ::.. Well thank a lot for so much update and effort to make your box working. Well i have a request, since i get lots of problem in finding the information. The request is to tell us what is the CPU / Hardware platform that a particular phone is so as to be able to get the PINS throught PIN FINDER. For example LG KG275 : how will i get the PINS? What Platform should i select to get the PINs through PIN FINDER. Please as far as you can, give us some information about which platform is WHICH mobile.. same as you did with PINOUTs when you select a model you get the PINOUTS throught the SHELL, can you please add this little INFORMATION about the HARDWARE PLATFORM also!!! Thanks Zakiyy PS; What is the PLATFORM for LG 275???? |
05-07-2008, 19:50 | #2 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: GUESS
Member: 252324 Status: Offline Sonork: 100.1589537 Thanks Meter: 29 | Quote:
05-07-2008, 19:52 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | hehehe pinout can be obtain frm mt62xx etc only.. or u can choose the right cable & manually enter 12: tx 13: rx power on phone and open infinity s/w & wrk or more simple use kg800 cable hahaha BR khemal |
05-07-2008, 21:59 | #5 (permalink) |
No Life Poster Join Date: Oct 2005 Location: egypt
Member: 194207 Status: Offline Sonork: 100.1602647 Thanks Meter: 167 | yes please infinity team we need that give us solution or trick for that cause we need to use pin finder for all phones that who u don't type its pinout i know that i can use the normal cable for the model but i want to use pin finder mony_valley |
05-08-2008, 02:41 | #6 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | @khem Ok thx for the INFO already tried all possibilites WHAT U MENTION that why am posting this THREAD.. But didnt get it !! Just imagine to choose EACH CPU and the amount of time to wait for the POSSIBILITIES to get the right ONE!! SO better get it right ONCE !!! And afterall its not a BIG deal!!! Did you answer my question what is LG KG 275 CPU name? PS: Just for the INFORMATION the phone is already unlock with LG k800 cable !! Why not with PIN FINDER? |
05-08-2008, 14:51 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @khem KG275 CPU is "Infinieon e-gold" @all You don't need to know CPU type if you want to set pinout manually, just use known pinout and set Rx/Tx pins manually. here is an instruction how to do that: http://www./showthread.php?t=526956 CPU types for all supported models: we will think how to make information easy to understand, also we are working now to build complete phone database for manual pinout selection in seconds with PinFinder. |
05-08-2008, 18:22 | #9 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | @Khem Wrong ... Hehehe, KG275 CPU is "Infinieon e-gold" @InfinitySupport Well entering it manually is not a problem, the problem is when you want to FIND the PINS, casue sometimes the TX and RX got from the SHELL/pinouts does not match.. e.g is ZTE A35 where the PINS TX and RX does not match at all what is in the SHELL/pinouts display (well for me it was like that).. That why, its better to remake a new search for the right PINS, not problem we can wait until pins are found. But we have to know the CPU model to be able to get the PINS.. AM i right? Please CORRECT me if am wrong. Thanks, Zakiyy |
05-08-2008, 20:10 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @zakiyyboss It's not a problem, if you will have a questions regarding phone model just ask here and I'll tell you what CPU is in your phone. f.e. ZTE-A35 has "Infinineon e-gold" CPU. Please, let me not to make list of phone/CPU for all models supported by Infinity-Box because I'll be really tired to make more that 2,000 (two thousands) models list. Btw, what is the problem with ZTE-A35 pinout ? Please, give me more details about correct pinout for this model. p.s. If you have any problems with manual pin configuration you can try to swap Rx/Tx (just one PinFinder button click and Rx/Tx will be swapped). This may helps you in many situations. |
infinity pin finder can't detect spredtrum cpu pin out perfectly | md.giousuddinso | Infinity-Box | 6 | 10-05-2009 19:08 |
pin finder and 2nd cpu | CHERIFA | Infinity-Box | 2 | 07-23-2009 16:27 |
it is possible to detect spreadtrum cpu with pin finder ? | unlock & flash | Infinity-Box | 1 | 03-29-2009 21:00 |
pin finder not decting this CPU !!! | zakiyyboss | Infinity-Box | 3 | 09-07-2008 16:04 |
Auto Pin Finder 2nd Cpu | Mansoor | Infinity-Box | 12 | 06-06-2008 08:04 |
