05-28-2009, 10:10 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Lg kf510 connectivity with infinity box:)- COM2 [VCP3] selected module v1.65 Device: LG-KP100 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! s-gold2: C0 loading... error: can't run preloader: 2000 boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Failed Finished, time used: 30 sec Remove/Install battery now ! I AM USING KE500 CABLE HERE IS READ GENERAL INFORMATION LOG Phone must be SWITCHED ON ! Connecting, wait... Connection Ok Read info... software version: KF510AT-00-V10g-404-XXX-JUN-19-2008+0 imei: 3530230xxxxxxxxxx Done Finished THE SET IS SECURTIY LOCKED HOW CAN I REMOVE IT HOPE INFINITY WILL SOON ADD IT IN ITS LIST WBR sahil2000ind |
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post: |
05-28-2009, 10:19 | #3 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | I HAVE ALSO TRIED TO CONNECT IT LIKE KF600 HERE IS THE LOGS FOR READ EPROM COM2 [VCP3] selected module v1.65 Device: LG-KF600 Checking data, wait... Action: read eeprom Boot ... Press and HOLD Power button now ! s-gold3: D4 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... completed Finished, time used: 51 sec Remove/Install battery now ! HERE IS THE LOGS FOR READ CODE SP UNLOCK Checking data, wait... Action: unlock read unlock codes Boot ... Press and HOLD Power button now ! s-gold3: D4 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... flash: 0000:0000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory ... loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes Finished, time used: 40 sec Remove/Install battery now ! WBR sahil2000ind |
05-28-2009, 10:55 | #4 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | chk with old Quote:
hi brother try to unlock with old version like 1.58 bcoz kf600 unlock with old version correctly thanks for this info | |
05-28-2009, 11:03 | #5 (permalink) | |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
HOPE WE CAN UNLOCK IT WITH INFINITY WBR sahil2000ind | |
05-28-2009, 14:33 | #6 (permalink) | |
Member: 171512 Status: Offline Thanks Meter: 1,034 | whats show Quote:
2945#*71001# Engineering mode for ===>>>>>>> 1809#*360# then select 5 for Factory Reset. If this help you ===>> press 1806#*360# reset it br, M.KALEEM | |
12-08-2009, 14:36 | #7 (permalink) |
Freak Poster Join Date: Oct 2001 Location: netherlands.antillies Age: 48
Member: 6879 Status: Offline Thanks Meter: 32 | Hey my brothers just use microbox all in one then use factory reset and thats it take care 09:32:19 > lg kf510 factory reset: Start! 09:32:20 > reading imei: Ok! 09:32:20 > imei: -------------------- sory cant show u:d 09:32:20 > factory reseting: Ok! 09:32:20 > lg kf510 factory reset: End:d! |
12-08-2009, 14:51 | #8 (permalink) | |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | Quote:
12-08-2009, 14:54 | #9 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
this is not M****'s section BR Faisal_Computer | |
Lg kc910 qualcom connect ok with infinity box:) | sahil2000ind | Infinity-Box | 1 | 01-20-2010 12:24 |
Samsung b279 cdma locked (virgin mobile) connect ok with infinity box:)- | sahil2000ind | Infinity-Box | 12 | 07-18-2009 16:06 |
HAIER C5000 V6 Mar 12 2009 CONNECT OK WITH INFINITY BOX:)- | sahil2000ind | Infinity-Box | 6 | 06-30-2009 20:10 |
Huawei c2906 connect ok with infinity box:)- | sahil2000ind | Infinity-Box | 0 | 06-18-2009 07:22 |
China unicon zte c330 cdma connect ok with infinity box:)- | sahil2000ind | Infinity-Box | 2 | 05-03-2009 09:20 |
