LG KF600 cant be unlock by both method Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes Finished, Remove/Install battery now ! Time used: 63 sec |
Lot of times it has been discussed here. You should search before post. By the way, your solution is HERE |
