-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   LG KF600 Unlock Successfully (http://forum.gsmhosting.com/vbb/f296/lg-kf600-unlock-successfully-616216/)
Sahil2007 10-23-2008 15:40
COM4 [VCP0] selected
Device: LG-KF600
Checking data, wait...
Action: unlock
direct unlock
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud...
921600
Set Baud Done
Connecting...
flash: 0000:0000
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
Check parameters Done
backup critical area...
reading [eeprom-sta]...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KF600_eeprom-sta_20081023-193329.B1E.bin
loading data...
data loaded
imei: 35200902345779400
backup critical area Done
Check memory...
loading data...
data loaded
loading data...
data loaded
loading data...
data loaded
loading data...
data loaded
code: 25124302
code: 0000000000000000
Check memory Done
Write...
Writing: eeprom-sta
Verifying...
Done
Write Done
Finished, Remove/Install battery now !
Time used: 28 sec
Thanks Infinity Team.;)
zeel_zeel 10-23-2008 15:42
Good test report. Infinity is the best unlocking tool.
InfinitySupport 10-23-2008 16:18
@Sahil2007
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Seedy 10-23-2008 23:50
Did direct unlock and codes but did not unlock
Device: LG-KF600
Action: unlock
read unlock codes
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0000:0000
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
loading data...
error: source buffer too small: 00000000 instead of 000035AE
Check memory...
loading data...
error: can't read codes
Time used: 42 sec
Unlocked first time with Micro Box
Sahil2007 10-24-2008 13:29
Device: LG-KF600
Action: unlock
read unlock codes
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0000:0000
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
loading data...
Check memory...
loading data...
Time used: 42 sec
http:///vbb/showpo...6&postcount=41 plz read this post befor unlock lg kf600
mazhar_dha 10-25-2008 10:22
great job thanks Infinity Box team keep it up
elpocitano 10-25-2008 16:56
Works.
But please, need flash with spanish please.
Thanks, good support.
angelcelu 10-25-2008 19:01
ATTENTION: after flashing your phone will have the next languages: En, Ru, Ua, Ee, Lv, Lt, Kz
there are some firmware kf600 with Spanish language
..::proudcracker::.. 10-26-2008 07:43
good job thnx
infinity team keep it up
turanla 10-28-2008 14:34
there are some firmware kf600 with germany and polnish language pls.
manyosa 12-09-2008 07:47
Good job i have manage to unlock KF600 with this error
Device: LG-KF600
Action: unlock
read unlock codes
Boot...
loading...
next part...
boot answer: 01
Boot Done
Set Baud...
115200
Set Baud Done
Connecting...
flash: 0000:0000
Connecting Done
Check hardware...
Check hardware Done
Check parameters...
loading data...
Check memory...
loading data...
Time used: 42 sec
By this process.
http://forum.gsmhosting.com/vbb/show...6&postcount=41
Keep it up.
InfinitySupport 12-09-2008 09:12
Hello,
Please, check link again. It is need to flash phone before unlock.
manyosa 12-09-2008 09:20
yes i have flash it and then direct unlock it.Now its unlocked
Redtan_70 12-09-2008 09:45
thats why i both a infinity box, cause they are there to help or guide as.
good job..........
Page generated in 0.52765 seconds with 5 queries
