Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: ATF Earth Age: 25
Member: 598395 Status: Online Thanks: 623
| LG KF600 Unlock Successfully COM4 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KF600_eeprom-sta_20081023-193329.B1E.bin loading data... data loaded imei: 35200902345779400 backup critical area Done Check memory... loading data... data loaded loading data... data loaded loading data... data loaded loading data... data loaded code: 25124302 code: 0000000000000000 Check memory Done Write... Writing: eeprom-sta Verifying... Done Write Done Finished, Remove/Install battery now ! Time used: 28 sec Thanks Infinity Team. |
| The Following 6 Users Say Thank You to Sahil2007 For This Useful Post: |
| | #3 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| @Sahil2007 Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2001
Member: 8102 Status: Offline Thanks: 2
| Did direct unlock and codes but did not unlock COM4 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes Finished, Remove/Install battery now ! Time used: 42 sec Unlocked first time with Micro Box |
| | #5 (permalink) | |
| Quote:
| The Following 3 Users Say Thank You to Sahil2007 For This Useful Post: |
| | #8 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2007 Location: MX-KEY is the BEST NOKIA TOOL
Member: 558475 Status: Offline Thanks: 40
| Quote:
there are some firmware kf600 with Spanish language | |
| | #10 (permalink) |
| Registered User ![]() Join Date: Oct 2006 Location: GERMANY
Member: 364551 Status: Offline Thanks: 145
| ATTENTION: after flashing your phone will have the next languages: En, Ru, Ua, Ee, Lv, Lt, Kz there are some firmware kf600 with germany and polnish language pls. |
| | #11 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks: 58
| Good job i have manage to unlock KF600 with this error Did direct unlock and codes but did not unlock COM4 [VCP0] selected Device: LG-KF600 Checking data, wait... Action: unlock read unlock codes Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0000:0000 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... loading data... error: source buffer too small: 00000000 instead of 000035AE backup critical area Done Check memory... loading data... error: source buffer too small: 00000000 instead of 000035AE error: can't read codes Finished, Remove/Install battery now ! Time used: 42 sec By this process. 16 Jun 2008: LG-KF600 model supported Keep it up. |
| The Following User Says Thank You to manyosa For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| LG-KF600 unlocking | Yashaka | Infinity-Box | 7 | 03-10-2009 05:59 |
| LG KF600 unlock Sucessfully By Micro box | NO.7 | Basic Micro-Box Software Support | 2 | 09-11-2008 11:07 |
| lg kf600 unlock help | combocharl | LG | 5 | 09-08-2008 16:57 |
| lg kf600 unlock code | mickle1 | allGSMunlock MultiOnline Remote Server | 5 | 07-02-2008 08:39 |
| LG KF600 Unlock | jt01934 | LG | 1 | 04-23-2008 16:56 |
