07-22-2007, 19:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: INDIA
Member: 363308 Status: Offline Thanks Meter: 79 | LG kG 110 after flash.......??? i have a LG KG 110 first it was restarts i flash with KG110P40FL-91-V10a-404-XX_2006-09-29_Code[1].B1M KG110P40FL-91-V10a-404-XX_2006-09-29_Alchemy_En_Fr_Tr_Pt_Es_Hindi_Marathi[1].B1P this file...after that phone on showing white display i search forum and did same like this.. /vbb/showthread...0+flash&page=2 discussion but no any result please help me .... |
07-22-2007, 22:41 | #3 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | there is no difference if u choose different version, i get same problem with infinity with same or different flash file, same like the posted pic just use original GSMMULTI v2.0 and flash ur phone with any version u want, all are on forum converted flash of infinity are not good |
07-23-2007, 07:15 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Cuttack,India Age: 54
Member: 71721 Status: Offline Sonork: 100.106320 Thanks Meter: 139 | Quote:
but one of them is imei corrupted please if you have any solution??? here is my post /vbb/showpost.p...0&postcount=10 | |
07-23-2007, 15:11 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @BouRRi_GSM @TURNING POINT @sartaj Could you, please, describe the problem exactly, with flashing logs, files names etc. This will helps to solve the problem (if it's really exist). |
07-23-2007, 19:26 | #10 (permalink) |
Member: 111457 Status: Offline Thanks Meter: 967 | problem is same like pic posted by unlock_org i don't remember file name because i delete them from my PC, but i try different file otherwise with GSM Multi different version work ok |
07-23-2007, 20:13 | #11 (permalink) | |
after unlock i checked imei is corrupted still work with airtel all sim but with another provider call failed(before unlock imei not checked) so i flashed with infinity v10a--result set dead flashed again with v10d--result white screen and some black spot on screen(ring tone sound is ok but restart ) but after flashed with GSMMULTI v10g phone is powered on but still imei corrupted again i flashed with infinity v10g phone dead again flashed with GSMMULTI same verson phone powered on again already checked after rework flash ic also fone before was v10d i tried 2 different ok phone same result with infinity...but alive again with GSMMULTI flashing procedure which i already done with different verSon and THIS procedure flashing and eeprom write log log already posted here and here if you need more phone to test i can arrange | |
07-24-2007, 11:22 | #12 (permalink) | |
Member: 363308 Status: Offline Thanks Meter: 79 | Quote:
so please try to out of this i flash with gsmmulti working please do it fast. we belive on infinity`s good support. thanks Mr. turning pont. wbr infinity user | |
no network KG 110 after flashing... | dapinderjit | Infinity-Box | 1 | 03-20-2010 06:51 |
Help !!!! Flash For Lg Kg 110 | KHALOUDA07 | LG | 0 | 02-05-2008 21:37 |
lg kg 110 unlock-to infinity team | sudeeshveekey | Infinity-Box | 13 | 05-30-2007 06:03 |
lg kg 110 dead after falsh | chiragp | Multi-Box | 3 | 05-02-2007 12:47 |
unlocker of lg kg 110 | andy_ind | LG | 1 | 12-02-2006 11:41 |
