Old 01-01-2009, 11:47   #1 (permalink)
Member: 174094
Thanks Meter: 74
lg kg 200 prob
lg kg200 without sim ok but with sim quickly goes off& where are pinouts
any help
thanks
Old 01-01-2009, 12:09   #2 (permalink)
Member: 453862
Thanks Meter: 53
Format Complete and repair IMIE
Old 01-01-2009, 12:17   #3 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
Thanks Meter: 2,390
try to factory reset 2945#*#..........................thanks
The Following 4 Users Say Thank You to R@jusat For This Useful Post:
Old 01-01-2009, 12:35   #4 (permalink)
Member: 453862
Thanks Meter: 53
Yes brother R@jsat u are right clear NVRam
by using this code
may problem solved
Old 01-02-2009, 09:52   #5 (permalink)
Member: 174094
Thanks Meter: 74
i did this procedure but same prob& i'm not sure if bad batt can do so
i havent any to replace it
Old 01-02-2009, 22:45   #6 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Hello,
Did you tried to make 112/emergency call without sim card ?
What is the results ?
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
lg kg 200 hung on lg logo help infinity pakmobiles Infinity-Box 6 08-21-2009 12:55
lg kg 200 prob habibkhalil Infinity-Box 6 01-03-2009 21:24
LG KG-200 Hang On LG Mono........... dil_PAKISTANI Infinity-Box 1 03-26-2008 18:05
Lg KG 200 phone lock code rockgsm LG 28 09-04-2007 09:29
Lg Kg 200 Kg300 Kg320 ch_rathore ULT PRO 0 08-07-2007 08:41
Page generated in 0.16065 seconds with 11 queries
