08-01-2007, 12:32 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: manisa\akhisar Age: 46
Member: 159363 Status: Offline Thanks Meter: 21 | LG kg 220 simlock error Device: LG KG220 Checking data, wait... advanced flash detection active Action: unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... error: boot failed: Release Power button ! error: unexpected answer during boot procedure Boot Fail error: no any expected answer Finished, time used: 8 sec Remove/Install battery now ! |
08-01-2007, 14:37 | #2 (permalink) |
Member: 159363 Status: Offline Thanks Meter: 21 | COM9 selected Device: LG KG220 Checking data, wait... advanced flash detection active Action: unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... error: boot failed: Release Power button ! error: unexpected answer during boot procedure Boot Fail error: no any expected answer Finished, time used: 8 sec Remove/Install battery now ! |
01-22-2008, 19:37 | #12 (permalink) |
Junior Member Join Date: Jul 2004 Location: Uzbekistan
Member: 71430 Status: Offline Thanks Meter: 0 | COM4 selected Device: LG KG220 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb id: 00005258 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: ******************x file saved: backup_eeprom_***************x_LG KG220_20080122-231011.B1E.bin ...... Check flash Done Check space... current eeprom imei: ***************xx ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 30 sec Remove/Install battery now ! 7050 cable ok |
@lg KG 220 | 4 u man | LG | 7 | 04-05-2011 18:50 |
lg kg 220 flash prob | habibkhalil | Infinity-Box | 0 | 10-31-2009 17:09 |
Lg KG.220 | qvadis | PolarBox 3 | 2 | 10-09-2008 23:09 |
LG KG 220 securtiy code Problem | aksamx | LG | 4 | 09-15-2007 18:33 |
Lg Kg 220 Sucessfully Unlocked | mvtamele | Infinity-Box | 1 | 07-23-2007 22:29 |
