Old 01-05-2009, 15:47   #1 (permalink)
Member: 263005
Thanks Meter: 147
Arrow LG KG 271 sim error
i have three kg 271 with sim error pls hlp me i try to hardware,full flash,unlock , but no result ,
Old 01-05-2009, 20:08   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Hello,
What text you see at phone LCD ?
Old 01-07-2009, 07:36   #3 (permalink)
Member: 263005
Thanks Meter: 147
display massage is "SIM ERROR''
Old 01-07-2009, 08:00   #4 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
try these solutions and post results ...
Well u know i also did the same discussed solutions but different LG models worked on different solutions...
Most surprising was Kg276 solution. I almost spent a day fixing it but still had same SIMCARD ERROR.. Later i opened the fone n soldered simcard jack n let screws not fully tight..
Surprisingly fone's not giving any errors now working just fine but wen i screw it tight it has the same SIMCARD Error..
So i guess there are number of things to sort this issue..
flash with infinity then unlock it
must b direct unlock method#2(Airtel.etc)
Faisal_Computer
Old 02-12-2009, 14:03   #5 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
sucses full repair LG KG276 SIM ERROR
The Following User Says Thank You to ali_imran For This Useful Post:
Old 02-12-2009, 14:46   #6 (permalink)
nadirghazi's Avatar
Member: 779665
Sonork: 100.1581784
Thanks Meter: 492
[quote=alimuamin;4032287]i have three kg 271 with sim error pls hlp me i try to hardware,full flash,unlock , but no result ,[/qu
you just need to change IMEI only
br
NADIR
The Following User Says Thank You to nadirghazi For This Useful Post:
Old 02-12-2009, 16:14   #7 (permalink)
madho's Avatar
Member: 647592
Thanks Meter: 191
no need to change imei only check unlock method u can see there in unlock method use airtel use it and do unlock 100000% solution check by me many time
The Following User Says Thank You to madho For This Useful Post:
Old 03-01-2011, 07:49   #8 (permalink)
Registered User
Member: 820646
Sonork: 100.1615032
Thanks Meter: 27
100% solution,thanks bro!
Lg kg-195 sim access error - final solution cel_phon Infinity-Box 14 09-30-2012 07:14
Lg kg 271 flash files .::AZEEM::. Infinity-Box 3 10-27-2009 00:45
lg kg 271 lilan sahoo Infinity-Box 3 04-26-2009 15:53
help me lg kg 800 sim jack naveed_me2 LG 0 11-14-2008 12:53
<< LG KG 271 Unlocked successfully By Infinity >> zeel_zeel Infinity-Box 1 08-07-2008 12:53
Page generated in 0.16740 seconds with 10 queries
