Old 10-28-2008, 04:09   #1 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
Lg KG-280 UNLOCK via infity the great
direct unlock using infinity
Device: LG-KG280
Checking data, wait...
advanced flash detection active
Action: unlock
unlock method: standard
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E223C2200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb
Boot Done
Set baud...
115200
Set baud Done
Check flash...
current eeprom imei: 3552220118HHHHH
current otp imei: 35522201180HHHH
file saved: C:\Program Files\InfinityBox\LGA\eeprom_35522201****_LG-KG280_20081027-180638.B1E.bin
version: utf-8,iso-8859-1,LG-KG280Obigo
Check flash Done
Check space...
current eeprom imei: 355222011moderetso_master
finalization done
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
write: lock area-1
Write Done
Finished, time used: 62 sec
Remove/Install battery now !
The Following User Says Thank You to aiyon_861 For This Useful Post:
Old 10-28-2008, 15:07   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Thank you very much for test report !
Each test report with attached logs is very important for us so we can see how is Infinity-Box
software works and what is possible problems and successfully done work.
Old 02-22-2012, 09:47   #3 (permalink)
Member: 509880
Thanks Meter: 16
COM4 [VCP0] selected
module v1.39
Device: LG-KG280
Action: unlock
Boot ...
Connecting, wait...
Release Power button now !
Boot Done
Set baud ...
460800
Set baud Done
Check flash ...
current eeprom imei: 355222010220722
current otp imei: 355222010220722
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355222010220722_LG-KG280_20120222-134642.B1E.bin
Check flash Done
Check space ...
finalization done
Check space Done
Check parameters ...
Erase ...
Erase Done
Write ...
write: lock area-1
Write Done
Finished, time used: 37 sec
good infinty team
The Following 2 Users Say Thank You to batishd2004 For This Useful Post:
romanian for LG KG 280 oviserv Infinity-Box 1 12-11-2008 17:07
-: Lg KG-280 UNLOCK via infity the great:- debmobile Infinity-Box 2 11-09-2008 21:01
posibile unlock lg kg 280 fany12ro ULT PRO 0 01-07-2008 10:31
lg kg 280 kyo74 FuriousGold 2 10-29-2007 20:13
lg kg 280 ikrash LG 0 08-03-2007 21:28
Page generated in 0.14130 seconds with 9 queries
