05-29-2009, 11:09 | #1 (permalink) |
Insane Poster Join Date: Jun 2007 Location: Lagos Nigeria
Member: 526790 Status: Offline Thanks Meter: 7 | lg kg 290 Big problem I tried flash KG 290 that is rebooting,the problem still persist,i wrote to inifity but no reply.Pls help me out COM7 [VCP0] selected Device: LG KG290 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005283 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 357456012683259 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35745601268325 9_LG KG290_20090521-095659.B1E.bin . . . . . . . . . . . . . . Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 89881600010001:89881600000000 Write: Alchemy data flash: 90009000900090:90909000000000 flash: 90009000900090:90909000000000 error: wrong write first sector at 0x00000000 Write Fail error: wrong answer[C5] Finished, time used: 52 sec Remove/Install battery now ! |
05-29-2009, 11:56 | #2 (permalink) |
Freak Poster Join Date: Dec 2007 Location: AGAIN TESION HERE Age: 39
Member: 644402 Status: Offline Sonork: dj_smti Thanks Meter: 197 | FG ON TESTED ..................GOOD JOB Press power on ! Starting communication ... Loader version: FuriouSTeaM GSM DEVELOPEMENT Baud rate changed ok ! Flash ID(0): 0089:8816:0101 READING INFO ... WAIT ! (CAN TAKE ~60s) IMEI: 3503052600XXXXXX LOCK: ON Writting... Done ! Time needed - 00:32:40 |
LG KG 290 Imei change problem please help | rashidrasheed81 | Infinity-Box | 4 | 02-13-2010 14:23 |
lg kg 195 big problem | bilal_mobile | LG Hardware Repair | 4 | 06-14-2009 16:10 |
lg kg 290 problem after change imei | prime_master786 | Infinity-Box | 4 | 03-06-2009 15:29 |
lg kg 290 problem after change imei | prime_master786 | HWK | 1 | 03-05-2009 18:10 |
problem whit lg kg 290 | raltelefonica | Infinity-Box | 17 | 03-02-2009 14:42 |
