11-06-2007, 15:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | LG KG110 dead after flash Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.22 S/N: 04F1:010C Wait... Current device: LG KG110 Done ==== log opened: [06.11.2007 15:23:31] ==== Application: C:\Program Files\InfinityBox\LGA\LgA.exe Loading data, wait... [Infinity Box] v1.22 S/N: 04F1:010C Wait... Current device: LG KG110 Done Loading file v.02... KG110P40-07-V10g-XXX-XX JAN 10 2007 CodeData_w_calibration[1].B1M.bin loaded Loading file v.02... KG130P40-07-v10a_XXX-XX_MAY-14-2007_alchemy[1].B1P.bin loaded Testing COM7 at 460800... COM7 [VCP6] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 355995010454967 current otp imei: 355995010454967 file saved: backup_eeprom_355995010454967_LG KG110_20071106-152542.B1E.bin ........ version: XXX-XX V10k AFR KG110P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 489 sec Remove/Install battery now ! Loading file v.02... backup_eeprom_355995010454967_LG KG110_20071106-152542.B1E.bin loaded Testing COM7 at 460800... COM7 [VCP6] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Skip: Firmware (code) Skip: File system Skip: Alchemy data Write: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 355995010454967 current otp imei: 355995010454967 file saved: backup_eeprom_355995010454967_LG KG110_20071106-155433.B1E.bin ........ version: XXX-XX V10g 07 KG110P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Eeprom flash: 01227E22212200:FEEA0000000000 Write Done Finished, time used: 30 sec Remove/Install battery now ! Loading file v.02... KG110P40-07-V10g-XXX-XX JAN 10 2007 CodeData_w_calibration[1].B1M.bin loaded Loading file v.02... KG130P40-07-v10a_XXX-XX_MAY-14-2007_alchemy[1].B1P.bin loaded Testing COM7 at 460800... COM7 [VCP6] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 460800 Set baud Done Check flash... current eeprom imei: 355995010454967 current otp imei: 355995010454967 file saved: backup_eeprom_355995010454967_LG KG110_20071106-155546.B1E.bin ........ version: XXX-XX V10g 07 KG110P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 49 sec Remove/Install battery now ! |
11-06-2007, 15:22 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
I hope you already see where it was your mistake. | |
03-04-2008, 18:22 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Age: 43
Member: 121662 Status: Offline Thanks Meter: 39 | Mate! 1st connect your phone then Flash your phone following file 1- KG110P40-20-V10b_602-03_MAY-31-2007_code 2- KG110P40-20-V10b_602-03_MAY-31-2007_alchemy_Arabic Then only go to Service option connect your phone again then press Reset settings option your phone live. |
Infinity Team! KG110 Dead after Flashing | supremegsm | Infinity-Box | 4 | 07-06-2007 17:46 |
LG G5300 dead after flashing | crossings | VygisToolbox | 4 | 01-28-2006 17:22 |
lg 8120 dead after flash | skull | MT-BOX | 1 | 12-05-2005 19:03 |
LG u8180 Dead After Flash with Redbox,Plz Help | citifone | Redbox | 0 | 08-30-2005 06:35 |
LG 8120 Dead after flash | 2stepmaster | LG | 20 | 06-16-2005 07:15 |
