09-23-2007, 04:18 | #1 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 50304 Status: Offline Thanks Meter: 13 | sams c140 problem I got one samsung c140 for unlocking i proceed as per documentation but the optiflash stops at "power on phone" during flashing the infinity c140 special file from suppport area. I selected right comport, right cable schematics rx tx, gnd and changed the various baud rates also. I am using slim plus box What could be the problem. Pl.help. |
09-23-2007, 17:20 | #3 (permalink) |
Member: 50304 Status: Offline Thanks Meter: 13 | Thanx for the promt reply I once again checked the com port and cable every thing ok. when I pressed the power on button as asked by optiflash, the phone gets powered on and it has not been detected at all. Is there any TP or something Pl.help thanx again |
09-24-2007, 18:37 | #5 (permalink) |
Member: 50304 Status: Offline Thanks Meter: 13 | I used pin out according to the pictures rx tx and gnd correctly. I interchanged rx and tx also for checking but no result. nothing wrong in rj45 cable.pinouts and comport settings and the phone is brand new. thanx |
09-24-2007, 18:59 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! correct pinout is available in our shell.exe program. did you make cable according this picture? each phone pin is marked with text where you can see to which box pin it must go |
09-25-2007, 20:36 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! well, you can try to make this by other programs, but i dont think this will help. Are you sure you setting right com port in flasher? you must set there com port which hold infinity box. you can see its number via Device manager |
Sam C140 Flashing Problem | az cells | Infinity-Box | 2 | 10-21-2007 17:05 |
techgsm.com - New Nokia cable, Moto F3 cable, Sam C140 Cable and more... | techgsm | Main Sales Section | 0 | 04-17-2007 22:17 |
Sam C140 unlock ??? | sepia | Samsung Flashers, Software, Firmware. | 5 | 03-26-2007 23:59 |
