Old 05-27-2008, 12:23   #1 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
Question LG kg110 IMEI corrupted
why infinity box not repair lgkg110 imei..........??????????
Old 05-27-2008, 12:28   #2 (permalink)
mughalG's Avatar
Member: 315789
Thanks Meter: 3,428
brother option to chagen imei is available .... are you facing problem so tell clearly plz
Old 05-27-2008, 12:42   #3 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
bro this function can change only eeprom imei not otp imei and always otp imei corrupt
Old 05-27-2008, 12:55   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
@yusufali786
for first time your stupid messages was only edited, for next time it will be simply deleted.
If you really have problem just post here detailed explanation of problem, if you have zero problem and zero explanatuion you must be silent !
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 05-27-2008, 13:07   #5 (permalink)
Member: 265606
Sonork: 1603113
Thanks Meter: 460
Current device: LG KG110
Done
COM6 ready
Testing COM6 at 921600...
COM6 [VCP0] selected
Device: LG KG110
Checking data, wait...
advanced flash detection active
Action: imei repair
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 354701011848657
current otp imei: 054701010000000
file saved: D:\Program Files\InfinityBox\LGA\backup_eeprom_35470101184865 7_LG KG110_20080521-044135.B1E.bin
version: 404-XXV10g91KG110P40FL
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
Write Done
Finished, time used: 74 sec
Remove/Install battery now !
why infinity-box cant change otp imei...........?????????????????????
Old 05-27-2008, 13:30   #6 (permalink)
Member: 130995
press *#06#
what you see at phone LCD ?
because OTP = one time programming area.
ONE TIME !
You must think before write next time !
Old 05-27-2008, 14:37   #7 (permalink)
tornado2008's Avatar
Member: 648590
Thanks Meter: 267
writ frmware file flash full in support area
KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M
and read txt
go to"Flash" page:
"Firmware (code)": checked
"File system": un-checked
"Alchemy data": un-checked
"Eeprom": un-checked
Load full flash file via "Load Firmware (code)" button
"Format FFS": un-checked
"Smart write": checked
"Keep calibration area": un-checked
The Following 5 Users Say Thank You to tornado2008 For This Useful Post:
Old 05-27-2008, 14:41   #8 (permalink)
Member: 158471
Sonork: 100.1588029
Thanks Meter: 120
hi infinity team i have same problem
*#06# see
03p0061000030000 0
Old 05-27-2008, 16:14   #9 (permalink)
Member: 130995
*#06# see
03p0061000030000 0
What was the reason to ignore previous messages in this thread ?
YOU MUST READ: http:///vbb/showpo...14&postcount=7
Old 05-27-2008, 20:56   #10 (permalink)
Member: 158471
Sonork: 100.1588029
Thanks Meter: 120
yes sir it work ok
BUT IF FLASHED PHONE AGAIN PROBLEM BACK
i read before writing new post
http://forum.gsmhosting.com/vbb/showthread.php?t=530461
phone have arabic lang this flash dosenot have arabic sir
th 4
Old 05-27-2008, 21:03   #11 (permalink)
Member: 130995
yes sir it work ok
th 4
Flashed with what ? Post here complete details.
Do you have your own experience ?
Old 08-20-2008, 07:46   #12 (permalink)
Member: 199814
Thanks Meter: 1,960
using this firmware the original imei will be converted as in file name?
and read txt
go to"Flash" page:
The Following User Says Thank You to asadnow2k For This Useful Post:
Old 08-21-2008, 08:44   #13 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M
JUST download this file from support n flash n u have working fone completely with its original IMEI,,,,BR
PROCEDURE STEP BY STEP
go to"Flash" page:
"File system" : un-checked
"Alchemy data" : un-checked
"Eeprom" : un-checked
Load full flash file via "Load Firmware (code)"button
"Format FFS" : un-checked
"Smart write" : checked
"Keep calibration area" : un-checked
then press write n wait till end...BR
The Following 2 Users Say Thank You to mobile_hotman For This Useful Post:
Old 09-03-2008, 16:20   #14 (permalink)
Member: 350948
Thanks Meter: 32
LG KG IMEI 0000 solved by this method........
KG 110 IMEi error 0000 solved by this procedure .
Thanks Infinity Team........
Old 09-06-2008, 15:14   #15 (permalink)
Member: 407338
Sonork: 100.1608994
Thanks Meter: 5
i have kg110 imei is showing 46065
i have flshed with infinity n chaged it with infinity with no luck
Lg Kg110 Imei 000000 reaz.com Infinity-Box 24 07-12-2009 18:27
lg kg110 imei corrupt gsmsikar HWK 1 01-17-2008 10:13
Lg Kg110 Imei Corrupt PASSIONATE_BOYS Infinity-Box 3 09-25-2007 19:30
lg kg110 imei crupted rajeshbahri LG 1 06-13-2007 08:55
Page generated in 0.30859 seconds with 9 queries
