LG kg110 IMEI corrupted why infinity box not repair lgkg110 imei..........?????????? ............ ??????????????????????? |
brother option to chagen imei is available .... are you facing problem so tell clearly plz :) |
bro this function can change only eeprom imei not otp imei and always otp imei corrupt ............... |
@yusufali786 for first time your stupid messages was only edited, for next time it will be simply deleted. If you really have problem just post here detailed explanation of problem, if you have zero problem and zero explanatuion you must be silent ! |
Current device: LG KG110 Done COM6 ready Testing COM6 at 921600... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 354701011848657 current otp imei: 054701010000000 file saved: D:\Program Files\InfinityBox\LGA\backup_eeprom_35470101184865 7_LG KG110_20080521-044135.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space... current eeprom imei: 354701011848657 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 74 sec Remove/Install battery now ! why infinity-box cant change otp imei...........????????????????????? |
press *#06# what you see at phone LCD ? because OTP = one time programming area. ONE TIME ! You must think before write next time ! |
writ frmware file flash full in support area KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M and read txt go to"Flash" page: "Firmware (code)": checked "File system": un-checked "Alchemy data": un-checked "Eeprom": un-checked Load full flash file via "Load Firmware (code)" button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked |
hi infinity team i have same problem *#06# see 03p0061000030000 0 |
YOU MUST READ: http:///vbb/showpo...14&postcount=7 |
yes sir it work ok BUT IF FLASHED PHONE AGAIN PROBLEM BACK i read before writing new post http://forum.gsmhosting.com/vbb/f177/lg-kg110-call-drop-problem-530461/ phone have arabic lang this flash dosenot have arabic sir th 4 |
Flashed with what ? Post here complete details. Do you have your own experience ? |
using this firmware the original imei will be converted as in file name? Quote:
JUST download this file from support n flash n u have working fone completely with its original IMEI,,,,BR PROCEDURE STEP BY STEP go to"Flash" page: "Firmware (code)": checked "File system" : un-checked "Alchemy data" : un-checked "Eeprom" : un-checked Load full flash file via "Load Firmware (code)"button "Format FFS" : un-checked "Smart write" : checked "Keep calibration area" : un-checked then press write n wait till end...BR |
LG KG IMEI 0000 solved by this method........ Quote:
Thanks Infinity Team........ |
i have kg110 imei is showing 46065 i have flshed with infinity n chaged it with infinity with no luck |
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
