05-27-2008, 12:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Rajasthan (Kota)
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | LG kg110 IMEI corrupted ............ ??????????????????????? Last edited by InfinitySupport; 05-27-2008 at 12:56. Reason: stupid text deleted |
05-27-2008, 12:42 | #3 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | bro this function can change only eeprom imei not otp imei and always otp imei corrupt ............... Last edited by InfinitySupport; 05-27-2008 at 12:56. Reason: stupid text deleted |
05-27-2008, 12:55 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @yusufali786 for first time your stupid messages was only edited, for next time it will be simply deleted. If you really have problem just post here detailed explanation of problem, if you have zero problem and zero explanatuion you must be silent ! |
05-27-2008, 13:07 | #5 (permalink) |
Member: 265606 Status: Offline Sonork: 1603113 Thanks Meter: 460 | Current device: LG KG110 Done COM6 ready Testing COM6 at 921600... COM6 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: imei repair Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 354701011848657 current otp imei: 054701010000000 file saved: D:\Program Files\InfinityBox\LGA\backup_eeprom_35470101184865 7_LG KG110_20080521-044135.B1E.bin ........ version: 404-XXV10g91KG110P40FL Check flash Done Check space... current eeprom imei: 354701011848657 Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 74 sec Remove/Install battery now ! why infinity-box cant change otp imei...........????????????????????? |
05-27-2008, 14:37 | #7 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | writ frmware file flash full in support area KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M and read txt go to"Flash" page: "Firmware (code)": checked "File system": un-checked "Alchemy data": un-checked "Eeprom": un-checked Load full flash file via "Load Firmware (code)" button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked |
The Following 5 Users Say Thank You to tornado2008 For This Useful Post: |
05-27-2008, 16:14 | #9 (permalink) | |
YOU MUST READ: http:///vbb/showpo...14&postcount=7 | |
05-27-2008, 20:56 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Location: egypt Age: 43
Member: 158471 Status: Offline Sonork: 100.1588029 Thanks Meter: 120 | yes sir it work ok BUT IF FLASHED PHONE AGAIN PROBLEM BACK i read before writing new post http://forum.gsmhosting.com/vbb/showthread.php?t=530461 phone have arabic lang this flash dosenot have arabic sir th 4 |
05-27-2008, 21:03 | #11 (permalink) | |
Flashed with what ? Post here complete details. Do you have your own experience ? | |
08-20-2008, 07:46 | #12 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | using this firmware the original imei will be converted as in file name? Quote:
The Following User Says Thank You to asadnow2k For This Useful Post: |
08-21-2008, 08:44 | #13 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | Quote:
JUST download this file from support n flash n u have working fone completely with its original IMEI,,,,BR PROCEDURE STEP BY STEP go to"Flash" page: "Firmware (code)": checked "File system" : un-checked "Alchemy data" : un-checked "Eeprom" : un-checked Load full flash file via "Load Firmware (code)"button "Format FFS" : un-checked "Smart write" : checked "Keep calibration area" : un-checked then press write n wait till end...BR | |
The Following 2 Users Say Thank You to mobile_hotman For This Useful Post: |
09-03-2008, 16:20 | #14 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: INDIA Age: 48
Member: 350948 Status: Offline Thanks Meter: 32 | LG KG IMEI 0000 solved by this method........ Quote:
Thanks Infinity Team........ | |
Lg Kg110 Imei 000000 | reaz.com | Infinity-Box | 24 | 07-12-2009 18:27 |
lg kg110 imei corrupt | gsmsikar | HWK | 1 | 01-17-2008 10:13 |
Lg Kg110 Imei Corrupt | PASSIONATE_BOYS | Infinity-Box | 3 | 09-25-2007 19:30 |
lg kg110 imei crupted | rajeshbahri | LG | 1 | 06-13-2007 08:55 |
