Old 09-06-2008, 15:28   #16 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
Exclamation
Originally Posted by rajeev13131 View Post
i have kg110 imei is showing 46065
i have flshed with infinity n chaged it with infinity with no luck
Brother see this and open ur eyes.
KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M
JUST download this file from support n flash n u have working fone completely with its original IMEI,,,,BR
PROCEDURE STEP BY STEP
go to"Flash" page:
"Firmware (code)": checked
"File system" : un-checked
"Alchemy data" : un-checked
"Eeprom" : un-checked
Load full flash file via "Load Firmware (code)"button
"Format FFS" : un-checked
"Smart write" : checked
"Keep calibration area" : un-checked
then press write n wait till end...BR
Old 09-07-2008, 07:55   #17 (permalink)
Member: 350948
Thanks Meter: 32
go to"Flash" page:
"Keep calibration area" : un-checked THEN U CAN USE TO CHANGE IMEI ............................
The Following User Says Thank You to shritelmob For This Useful Post:
Old 10-03-2008, 01:02   #18 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinty i have a mg110 with the same problem imei 00000.so i flashed with this flash for kg110
and imei is repaired but the problem is the the flash is for kg 110 so i doesnt have 850/1900
after i flash with mg110a flash but imei goes back to 00000
please infintiy team add full flash to repair this imei problem for mg110.
Gee4234
Old 10-03-2008, 08:16   #19 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, if you will have any good working MG110 on hands, read flash and send it to [email protected]
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 10-03-2008, 15:45   #20 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinity team
one just came in for unlock. before i unlock it i will read out flash and send to support. the flash is for movistar Argentina
Gee4234
Old 10-03-2008, 15:54   #21 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
Originally Posted by InfinitySupport View Post
Hello,
hello infinity team
here is rapidshare link for mg110a movistar flash as you requested.please add the repair flash for imei 00000 as soon as possible.
http://rapidshare.com/files/15057000...tinat.rar.html
Gee4234
Old 10-06-2008, 12:24   #22 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello imfinity team
please add mg110a repair for imei 00000 fullflash as soon as possible.
gee4234
Old 10-06-2008, 13:14   #23 (permalink)
Member: 130995
Hello,
I think files will be uploaded in support area today.
Old 10-07-2008, 11:42   #24 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinity team
thank you for adding fullflash
MG110aP40FL-54-V10a_722-07_SEP-8-2006_full_code_alchemy.B1M.bin
i have flashed phone with this flash but imei is still 00000
1. Go to software "Flash" page:
"File system": un-checked
"Alchemy data": un-checked
"Eeprom": un-checked
2. Load full flash file via "Load Firmware (code)" button
"Format FFS": un-checked
"Smart write": checked
"Keep calibration area": un-checked
3. Flash phone (press flash "Write" button)
COM4 [VCP6] selected
Device: LG-MG110
Checking data, wait...
advanced flash detection active
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" enabled
Boot...
Phone must be POWERED-OFF !
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 011006000084396
current otp imei: 011006000084390
file saved: D:\Archivos de programa\InfinityBox\LGA\eeprom_011006000084396_LG-MG110_20081007-074141.B1E.bin
version: 722-07V10a54MG110aP40FL
Check flash Done
Check space...
Check space Done
Check parameters...
Check parameters Done
Erase...
Erase Done
Write...
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 77 sec
Remove/Install battery now !
please help
Gee4234
Old 10-07-2008, 11:46   #25 (permalink)
Member: 130995
Hello,
try to flash phone with KG110 full flash file.
Let's see results.
Old 10-07-2008, 12:00   #26 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinity support
thank you for looking into my problem here is results after flashing
KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M.bin
Device: LG-KG110
Action: flash write
Skip: File system
Skip: Alchemy data
Skip: Eeprom
Boot...
Connecting, wait...
Boot Done
Set baud...
921600
Set baud Done
Check flash...
current eeprom imei: 011006003435876
file saved: D:\Archivos de programa\InfinityBox\LGA\eeprom_011006003435876_LG-KG110_20081007-075453.B1E.bin
Check flash Done
Check space...
Check space Done
Check parameters...
Erase...
Erase Done
Write...
Write Done
Finished, time used: 415 sec
imei is reoaired 352691010123453 but no network
gee4234
Old 10-07-2008, 12:07   #27 (permalink)
Member: 130995
Hello,
Try to flash phone with MG110 code + alchemy files.
Can you read full flash backup from any other good working MG110 ?
Old 10-07-2008, 12:20   #28 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinity team
i have flashed with code and alchemy files and it does not repair imei
the flashbackup i sent you was from a good working flash that came in for unlock.i made the backup before i unlocked the phone. the flash was untouched
Gee4234
Old 10-07-2008, 12:34   #29 (permalink)
Member: 130995
Hello,
Try to flash phone with MG110 code + alchemy files after KG110 full flash.
Old 10-07-2008, 12:59   #30 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinty team
i have tred that.after i repaired imei with kg110 fullflash.i flash with code and alchemy of mg110 to get correct bands but imei is set back to zero.and that is when i requested a mg110 fullflash to repair 00000.what is the difference between kg110 fullflash and mg110 fullflash other than one is for 900/1800 and the other is 850/1900.please modify the mg110 flash to repair 00000 imei.
GEE4234
Lg Kg110 Imei 000000 reaz.com Infinity-Box 24 07-12-2009 18:27
lg kg110 imei corrupt gsmsikar HWK 1 01-17-2008 10:13
Lg Kg110 Imei Corrupt PASSIONATE_BOYS Infinity-Box 3 09-25-2007 19:30
lg kg110 imei crupted rajeshbahri LG 1 06-13-2007 08:55
Page generated in 0.18352 seconds with 9 queries
