Old 10-07-2008, 19:07   #31 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
I think it's need to get MG110 full flash backup with another firmware version, not the same as you have sent to us.
Can you try to read more full flash from other good phones ?
Old 10-08-2008, 11:48   #32 (permalink)
gee4234's Avatar
Member: 86579
Thanks Meter: 70
hello infinity support
ok as soon as another comes in for unlock i will readout the flash and send to you.thank you.
Gee4234
Old 12-16-2008, 10:38   #33 (permalink)
Member: 216616
Thanks Meter: 11
hi
can somebody tell me where to find KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M cuz its not present in support area
Old 12-16-2008, 11:44   #34 (permalink)
Member: 130995
Originally Posted by saaqi View Post
hi
Hello,
There is a difference in words: "no files in support" and "you are unable to find required files".
Please, DO NOT make respected Infinity-Box users confused !
You must search files in support area better before say not honest words !
You must check support area again: \flashfiles\LG\KG110\full_flash
I hope you will say here your "big sorry" so fast as possible.
Old 12-21-2008, 07:57   #35 (permalink)
Member: 743624
Thanks Meter: 54
Originally Posted by tornado2008 View Post
writ frmware file flash full in support area
KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M
and read txt
go to"Flash" page:
"Firmware (code)": checked
"File system": un-checked
"Alchemy data": un-checked
"Eeprom": un-checked
Load full flash file via "Load Firmware (code)" button
"Format FFS": un-checked
"Smart write": checked
"Keep calibration area": un-checked
Its 100% Work
THANKS
Old 06-06-2009, 17:16   #36 (permalink)
Member: 983750
Thanks Meter: 26
today i also repair kg 110 imei by infinity files taken by fullflash folder from support area and read text how to flash and follow rules
sorry bcoz before i write infinity cant repair imei of lg kg 110
Old 08-07-2009, 11:41   #37 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 61
I am also facing the same Problem..
Loading file v.02...
KG110P40-20-V10b_602-03_MAY-31-2007_full_code_alchemy.B1M.bin loaded
Testing COM3 at 460800...
==== log: [7/Aug/2009 3:48:07 PM] ====
COM3 [VCP0] selected
module  v1.38
Device: LG-KG110
Checking data, wait...
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
460800
Set baud Done
Check flash ...
current eeprom imei: 355323020256241
current otp imei: 355995013866159
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355323020256241_LG-KG110_20090807-154828.B1E.bin
version: XXX-XXV10jESAKG110P40
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 944 sec
Remove/Install battery now !
==== log: [7/Aug/2009 4:04:12 PM] ====
module  v1.38
Device: LG-KG110
Action: imei repair
Boot ...
Connecting, wait...
Boot Done
Set baud ...
460800
Set baud Done
Check flash ...
current eeprom imei: 355995016533764
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995016533764_LG-KG110_20090807-160435.B1E.bin
version: 602-03V10b20KG110P40
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 27 sec
But Even After this, IMEI with *#06# is 00000000000000
How to rebuilt this!!!!!
Thanks
Old 08-07-2009, 12:01   #38 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 61
Problem Solved with use of Another Flash File
Thanks
Old 12-07-2009, 19:09   #39 (permalink)
Member: 321173
Smile
kg110p40fl-91-v10d_404-xx_oct-16-2006_full_code_alchemy_352691010123453.b1m
and read txt
go to"flash" page:
"firmware (code)": Checked
"file system": Un-checked
"alchemy data": Un-checked
"eeprom": Un-checked
load full flash file via "load firmware (code)" button
"format ffs": Un-checked
"smart write": Checked
"keep calibration area": Un-checked
thank you very much my problom have been solved
thanks for best regards
alok
Old 08-10-2010, 15:16   #40 (permalink)
Member: 1093822
Thanks Meter: 14
Originally Posted by rajeev13131 View Post
i have kg110 imei is showing 46065
i have flshed with infinity n chaged it with infinity with no luck
Use UFSx LG-Gsm
Select Model
and tool IME
and edit set Imei and write
if first time fail restart set and try second time
Your Problem solved
Anjali Mobile
Kuchaman City
Happy to Help
I have same problem in KG110
its shows imei 63000
show Network and call drop after making Call
use infinity box but no luck
after i use ufsx LG-Gsm
and my problem solved
Lg Kg110 Imei 000000 reaz.com Infinity-Box 24 07-12-2009 18:27
lg kg110 imei corrupt gsmsikar HWK 1 01-17-2008 10:13
Lg Kg110 Imei Corrupt PASSIONATE_BOYS Infinity-Box 3 09-25-2007 19:30
lg kg110 imei crupted rajeshbahri LG 1 06-13-2007 08:55
Page generated in 0.21819 seconds with 9 queries
