06-15-2009, 09:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | LG KG110 IMEI damaged !! solution here ... How to repair 000... (all zeroes) imei for LG KG-110: Download files from support area folder: \flashfiles\LG\KG110\full_flash 1. Go to software "Flash" page: "Firmware (code)": checked "File system": un-checked "Alchemy data": un-checked "Eeprom": un-checked 2. Load full flash file via "Load Firmware (code)" button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked 3. Flash phone (press flash "Write" button) Code: COM2 [VCP0] selected module v1.38 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 230400 Set baud Done Check flash ... current eeprom imei: 352691014460398 current otp imei: 352691014460398 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691014460398_LG-KG110_20090615-141528.B1E.bin ........ version: 404-XXV10a91KG110P40FL Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 796 sec Remove/Install battery now ! |
The Following 9 Users Say Thank You to reaz.com For This Useful Post: |
11-05-2009, 08:34 | #3 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 786285 Status: Offline Sonork: [email protected] Thanks Meter: 11 | not work........... any solution......... |
11-10-2009, 03:58 | #5 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: in your Heart
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | Imei 0000 Quote:
I have full flashed kg 110 but still imei 0000. i have followed the method exactly 1. Go to software "Flash" page: "Firmware (code)": checked "File system": un-checked "Alchemy data": un-checked "Eeprom": un-checked 2. Load full flash file via "Load Firmware (code)" button "Format FFS": un-checked "Smart write": checked "Keep calibration area": un-checked 3. Flash phone (press flash "Write" button) any other solution please thanks | |
11-10-2009, 04:04 | #6 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: inside nck
Member: 628112 Status: Offline Sonork: 100.1589052 Thanks Meter: 3,726 | Quote:
write original imei after flash completed regards, | |
11-10-2009, 04:19 | #7 (permalink) |
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | here is the log of full flash Code: COM8 [VCP0] selected module v1.38 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: flash write Write: Firmware (code) Skip: File system Skip: Alchemy data Skip: Eeprom "smart write" active Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 354701015233260 current otp imei: 000000000000000 file saved: C:\Program Files\InfinityBox\LGA\eeprom_354701015233260_LG-KG110_20091110-083701.B1E.bin ........ version: XXX-XXV10jESAKG110P40 Check flash Done Check space ... Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write: Firmware (code) flash: 01227E22212200:FEEA0000000000 flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 286 sec Remove/Install battery now ! |
11-12-2009, 13:58 | #11 (permalink) |
Member: 888557 Status: Offline Sonork: 100.1608317 Thanks Meter: 34 | thanks bro full flashed & then wrote original imei many times still imei shows 0000 here is the log COM8 [VCP0] selected module v1.38 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: imei repair Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud ... 921600 Set baud Done Check flash ... current eeprom imei: 355995011768365 current otp imei: 000000000000000 file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995011768365_LG-KG110_20091112-182125.B1E.bin ........ version: XXX-XXV10jESAKG110P40 Check flash Done Check space ... current eeprom imei: 355995011768365 Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... Write Done Finished, time used: 42 sec Remove/Install battery now ! any other solution please |
12-16-2009, 07:52 | #15 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | if some time restart then its should be hardware problem or battery problem , check mobile's battery connectors clean it BR Faisal_Computer |
if u have lg b2060 IMEI 0000?SOLUTION IS HERE!!!! | Rin2 | Infinity-Box | 7 | 03-31-2011 14:39 |
Lg Kg110 Imei 000000 | reaz.com | Infinity-Box | 24 | 07-12-2009 18:27 |
lg kg110 imei corrupt | gsmsikar | HWK | 1 | 01-17-2008 10:13 |
Lg Kg110 Imei Corrupt | PASSIONATE_BOYS | Infinity-Box | 3 | 09-25-2007 19:30 |
lg kg110 imei crupted | rajeshbahri | LG | 1 | 06-13-2007 08:55 |
