-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   LG KG110 IMEI damaged !! solution here ... (http://forum.gsmhosting.com/vbb/f296/lg-kg110-imei-damaged-solution-here-769088/)
reaz.com 06-15-2009 09:39
Just flow this.....................
How to repair 000... (all zeroes) imei for LG KG-110:
Download files from support area folder: \flashfiles\LG\KG110\full_flash
1. Go to software "Flash" page:
"Firmware (code)": checked
"File system": un-checked
"Alchemy data": un-checked
"Eeprom": un-checked
2. Load full flash file via "Load Firmware (code)" button
"Format FFS": un-checked
"Smart write": checked
"Keep calibration area": un-checked
3. Flash phone (press flash "Write" button)
COM2 [VCP0] selected
module  v1.38
Device: LG-KG110
Checking data, wait...
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
230400
Set baud Done
Check flash ...
current eeprom imei: 352691014460398
current otp imei: 352691014460398
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691014460398_LG-KG110_20090615-141528.B1E.bin
version: 404-XXV10a91KG110P40FL
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 796 sec
Remove/Install battery now !
CONCORDIA GSM 06-15-2009 09:51
already postd many times before also present on infinity downloading site along with kg110 files. ;)
sadik ahmad 11-05-2009 07:34
not work........... any solution.........
InfinitySupport 11-05-2009 08:27
It works for sure.
You must follow the instruction exactly:
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Repair_imei_LG-KG110.txt
sidramobilecare 11-10-2009 02:58
Imei 0000
Originally Posted by InfinitySupport (Post 5004583)
It works for sure.
Dear Infinity team,
I have full flashed kg 110 but still imei 0000.
i have followed the method exactly
any other solution please
thanks
toutou_gsm 11-10-2009 03:04
Originally Posted by sidramobilecare (Post 5020182)
Dear Infinity team,
thanks
write original imei after flash completed
regards,
sidramobilecare 11-10-2009 03:19
here is the log of full flash
COM8 [VCP0] selected
module  v1.38
Device: LG-KG110
Action: flash write
Skip: File system
Skip: Alchemy data
Skip: Eeprom
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 354701015233260
current otp imei: 000000000000000
file saved: C:\Program Files\InfinityBox\LGA\eeprom_354701015233260_LG-KG110_20091110-083701.B1E.bin
version: XXX-XXV10jESAKG110P40
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 286 sec
mobilecitycbk 11-10-2009 03:26
regards,
Thanks brother its solve my problem
Asghar Hussain
pallumobile 11-10-2009 04:42
It works for sure.
Ok what about the other lg model like b2050 and b2060. Team must reply on this topic pls.
InfinitySupport 11-10-2009 17:08
Hello,
What is the problem with these models ?
sidramobilecare 11-12-2009 12:58
regards,
thanks bro
full flashed & then wrote original imei many times still imei shows 0000
here is the log
module v1.38
Device: LG-KG110
Action: imei repair
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 355995011768365
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995011768365_LG-KG110_20091112-182125.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 42 sec
InfinitySupport 11-12-2009 14:39
Hello,
Use this file: KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M.bin
sidramobilecare 11-20-2009 12:03
Originally Posted by InfinitySupport (Post 5028875)
Hello,
Thanks sir,
infinity has very good support
mkvineethmk 12-15-2009 08:48
thanks infinity imei is ok some time set in restart
Faisal_Computer 12-16-2009 06:52
if some time restart then its should be hardware problem or battery problem , check mobile's battery connectors clean it
Faisal_Computer
Page generated in 0.26935 seconds with 5 queries
