Old 06-15-2009, 09:39   #1 (permalink)
Member: 310155
Thanks Meter: 1,313
LG KG110 IMEI damaged !! solution here ...
Just flow this.....................
How to repair 000... (all zeroes) imei for LG KG-110:
Download files from support area folder: \flashfiles\LG\KG110\full_flash
1. Go to software "Flash" page:
"Firmware (code)": checked
"File system": un-checked
"Alchemy data": un-checked
"Eeprom": un-checked
2. Load full flash file via "Load Firmware (code)" button
"Format FFS": un-checked
"Smart write": checked
"Keep calibration area": un-checked
3. Flash phone (press flash "Write" button)
COM2 [VCP0] selected
module  v1.38
Device: LG-KG110
Checking data, wait...
Action: flash write
Write: Firmware (code)
Skip: File system
Skip: Alchemy data
Skip: Eeprom
"smart write" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
230400
Set baud Done
Check flash ...
current eeprom imei: 352691014460398
current otp imei: 352691014460398
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691014460398_LG-KG110_20090615-141528.B1E.bin
version: 404-XXV10a91KG110P40FL
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write Done
Finished, time used: 796 sec
Remove/Install battery now !
The Following 9 Users Say Thank You to reaz.com For This Useful Post:
Old 06-15-2009, 09:51   #2 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
already postd many times before also present on infinity downloading site along with kg110 files.
Old 11-05-2009, 08:34   #3 (permalink)
Member: 786285
Thanks Meter: 11
not work........... any solution.........
Old 11-05-2009, 09:27   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
It works for sure.
You must follow the instruction exactly:
C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ Repair_imei_LG-KG110.txt
Old 11-10-2009, 03:58   #5 (permalink)
sidramobilecare's Avatar
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
Imei 0000
Originally Posted by InfinitySupport View Post
It works for sure.
Dear Infinity team,
I have full flashed kg 110 but still imei 0000.
i have followed the method exactly
any other solution please
thanks
Old 11-10-2009, 04:04   #6 (permalink)
toutou_gsm's Avatar
Member: 628112
Sonork: 100.1589052
Thanks Meter: 3,726
Originally Posted by sidramobilecare View Post
Dear Infinity team,
thanks
write original imei after flash completed
regards,
Old 11-10-2009, 04:19   #7 (permalink)
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
here is the log of full flash
COM8 [VCP0] selected
module  v1.38
Device: LG-KG110
Action: flash write
Skip: File system
Skip: Alchemy data
Skip: Eeprom
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 354701015233260
current otp imei: 000000000000000
file saved: C:\Program Files\InfinityBox\LGA\eeprom_354701015233260_LG-KG110_20091110-083701.B1E.bin
version: XXX-XXV10jESAKG110P40
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 286 sec
Old 11-10-2009, 04:26   #8 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
regards,
Thanks brother its solve my problem
Asghar Hussain
Old 11-10-2009, 05:42   #9 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
It works for sure.
Ok what about the other lg model like b2050 and b2060. Team must reply on this topic pls.
Old 11-10-2009, 18:08   #10 (permalink)
Member: 130995
Hello,
What is the problem with these models ?
Old 11-12-2009, 13:58   #11 (permalink)
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
regards,
thanks bro
full flashed & then wrote original imei many times still imei shows 0000
here is the log
module v1.38
Device: LG-KG110
Action: imei repair
Boot ...
Connecting, wait...
Boot Done
Set baud ...
921600
Set baud Done
Check flash ...
current eeprom imei: 355995011768365
file saved: C:\Program Files\InfinityBox\LGA\eeprom_355995011768365_LG-KG110_20091112-182125.B1E.bin
Check flash Done
Check space ...
Check space Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 42 sec
Old 11-12-2009, 15:39   #12 (permalink)
Member: 130995
Hello,
Use this file: KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453.B1M.bin
Old 11-20-2009, 13:03   #13 (permalink)
Member: 888557
Sonork: 100.1608317
Thanks Meter: 34
Hello,
Thanks sir,
infinity has very good support
Old 12-15-2009, 09:48   #14 (permalink)
Member: 640980
Thanks Meter: 20
thanks infinity imei is ok some time set in restart
Old 12-16-2009, 07:52   #15 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
if some time restart then its should be hardware problem or battery problem , check mobile's battery connectors clean it
Faisal_Computer
if u have lg b2060 IMEI 0000?SOLUTION IS HERE!!!! Rin2 Infinity-Box 7 03-31-2011 14:39
Lg Kg110 Imei 000000 reaz.com Infinity-Box 24 07-12-2009 18:27
lg kg110 imei corrupt gsmsikar HWK 1 01-17-2008 10:13
Lg Kg110 Imei Corrupt PASSIONATE_BOYS Infinity-Box 3 09-25-2007 19:30
lg kg110 imei crupted rajeshbahri LG 1 06-13-2007 08:55
Page generated in 0.24597 seconds with 9 queries
