Old 07-03-2009, 17:03   #1 (permalink)
Member: 239168
Thanks Meter: 104
Lg kg110 reboot when backlight turn off
i have two lg kg110's same problem-set on-network ok-but at the time of backlight automatically off-set reboot-it repeats.
i searched in forum and saw a post of product supporter as below
same to me but i flash the fone this version my fone is ok {KG110P40FL-91-V10g-404-XX_NOV-17-2006_Code[1].B1M}{KG110P40FL-91-V10g-404-XX_NOV-17-2006_Alchemy[1].B1P}{KG110_repair_eeprom_calibration_0E_91[1].B1E} """""
so i flashed using above files-logs as below
COM5 [VCP0] selected
module v1.36
Device: LG-KG110
Checking data, wait...
Action: flash write
Write: Firmware (code)
Skip: File system
Write: Alchemy data
Write: Eeprom
"smart write" active
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 352691018698548
current otp imei: 35269108696252
file saved: C:\Program Files\InfinityBox\LGA\eeprom_352691018698548_LG-KG110_20090703-155944.B1E.bin
version: XXX-XXV10gARBKG110P40
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write: Alchemy data
flash: 01227E22212200:00000100000000
write: 2nd chip area
Write: Eeprom
Write Done
Finished, time used: 1178 sec
Remove/Install battery now !
but after flash also same problem-set reboot at the time of backlight off-
i think its hardware problem
am i right?
help me
thank u
Old 07-04-2009, 21:26   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Power-on phone and check it's imei: *#06#
What is imei value ?
Old 07-05-2009, 11:41   #3 (permalink)
Member: 239168
Thanks Meter: 104
Originally Posted by InfinitySupport View Post
Hello,
imei ok-35269101423650900
Old 07-05-2009, 11:49   #4 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
format again brother
Old 07-05-2009, 11:52   #5 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
flash main firmware
br
Old 07-05-2009, 16:13   #6 (permalink)
Member: 239168
Thanks Meter: 104
Originally Posted by venuno View Post
flash main firmware
br
formatted-flashed-still in reboot when backlight off(something do in keyboard then no problem)-so my doubt is it software?
Old 07-05-2009, 16:17   #7 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
download fullflash from support if affter flash with full flash you have a same probleme check hard
Old 07-05-2009, 17:12   #8 (permalink)
gsmbac's Avatar
Member: 44229
Sonork: 1592530
Thanks Meter: 366
disassemble phone, give power to bat pin using power supply,
power on then check some parts get hot.
br.
Nokia 2680 off when backlight off chipez Nokia Hardware & Hardware Repair 0 12-18-2009 07:14
SDIO WiFi turns off when XDA turns off bankir HTC & PDA WM( With Touchscreen) 0 09-06-2006 08:46
lg 510 reboot when insert sim card .::Zafar Communication::. VygisToolbox 0 07-11-2005 11:16
When dialling turns off aberiya Nokia Digital Core Technology 4 ( DCT-4 ) 9 01-13-2005 16:53
sl45 with fw56 powers off after backlight turns off gnoshi x1x to x45/x50 4 02-10-2004 00:24
Page generated in 0.23498 seconds with 9 queries
