LG KG110 repaired with flashing process this unit came to me for repair with program problem.when turned on the unit just hangs in the main menu.i hope this serves as reference for all of us....all i did was flash the unit with alchemy data and calibration files from the support site and load it then flash the unit... http://img444.imageshack.us/img444/8824/dsc00109ci4.jpg http://img525.imageshack.us/img525/2469/kg110cy7.jpg Logs For Flashing: COM4 [VCP0] selected Device: LG KG110 Checking data, wait... advanced flash detection active Action: flash write Write: Firmware (code) Skip: File system Write: Alchemy data Skip: Eeprom "smart write" enabled "keep calibration" enabled Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb id: 00005258 Boot Done Set baud... 921600 Set baud Done Check flash... current eeprom imei: 352691014915805 current otp imei: 352691014915805 file saved: C:\Program Files\InfinityBox\LGA\backup_eeprom_35269101491580 5_LG KG110_beforeflashingbackup20080124-154422.B1E.bin . . . . . . . . version: ***-XXV10gARBKG110P40 Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware (code) calibration area skipped flash: 01227E22212200:FEEA0000000000 Write: Alchemy data flash: 01227E22212200:00000100000000 write: 2nd chip area Write Done Finished, time used: 370 sec Remove/Install battery now ! after flashing the unit is now well and full functional. |
thanks for ur info regards! |
u post only logs here. tell step by step all steps u taken during this process. |
sorry posted in the wrong thread. |
